Results 1 to 5 of 5
Thread: Fault Code Question
    VZ Executive
    Mar 2011
    Default Fault Code Question
    I have a fault code coming up on my scan tool saying U0155 CAN-BUS NO COMM. WITH GATEWAY
    my commodore has been running rough. What my understand is that the part i plug into my scan tool to read holden commodores. though in the past if i have the wrong plug the scan tool tells me to change. but it is coming up with this faul code and i'm not sure where to go from here.
    any help would be appreciated
    ashbox's Avatar
    ashbox is online now 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    i'm guessing for some reason your scan tool isn't picking up your vz
    Chev badges are an instant fail
    vz executive
    Mar 2011
    my fault code is ABS FAULT,,,even though my holden dealer says nothing is wrong
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    U0155 on my tool reads, 'no communication with instrument panel cluster control module (IPC)'.
    You are going to have to explain further. I'm at a loss to make any sense of your question.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    CAN BUS NO COMMS codes usually dont pose an issue and if you clear it it probalby wont come back. Does your scan tool say whether its present/current or not present/history?
    It could have been thrown when cranking and the voltage wasnt high enough to support all the modules hence the no communication part.
    Silver Certified.
  1. vz sv6 fault code
    By yandan in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-11-2010, 04:44 PM
  2. Fault Code 22 - quick question
    By Gosling1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2010, 10:26 PM
  3. Fault code 66
    By customfc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2008, 07:41 PM
  4. Fault Code 22
    By Tom_1569 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2008, 04:35 PM
  5. ECU Fault code
    By TigerVX in forum Electrical Wiring / Questions
    Last Post: 26-07-2005, 05:55 PM
