not sure if its illegal but if anyone wants i can post the instructions on how to get rid of the service message on your vehicle (VZ executive) that dealers i think use?
give me $20 and il do ithold the mode and set, turn the key to acc, hold set for 10 sec, and it should be all good
Oh no now Im out of a job.
Silver Certified.
Probably anywhere from $150 as they will only usually do it when "they" service the car.
But as others have said this procedure has been around for ages.
VZ Trip Computer "Service Reminder" reset
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
Removal of the Service Reminder message is not illegal. The Dealers / Techies program it in as a courtesy, even if people think of it as otherwise. And the instructions on how to do it are readily available here on the forum. As others have said here, it's been around literally since Nelson lost an eye. Go search...![]()
•:*¨¨*:•.When you start your car, does it return the favour?•:*¨¨*:•.
Originally posted by soop
Your arse is going to sting for a while, and then worse when it does bugger all.![]()
