Results 1 to 8 of 8
Thread: VZ beep on door locking
    04 VZ SV6 A5
    Feb 2010
    Default VZ beep on door locking
    My sv6 has started to beep the horn 3 times whenever i am locking the car up, i know this is mean to advise you that a door is not fully shut but all 4 are and it is beginning to really irritate me, is there some sort of a button which is depressed when you shut the door which might not be getting fully pressed? anyone had similar issues???
    WL CAPRICE
    Mar 2011
    hi
    dads vy had that problem aswell, its one of the four door knobs not functioning rite, so it does that to notify u that the car isnt fully locked.
    have a look at all four knobs and observe wether they go down when u lock the car or not.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Ditto as Davviid said, had the same happen to my senator and also to my old VS wagon..
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    2006 VZ commodore Acclaim
    Jan 2007
    Ipswich QLD :(
    Push the up or down arrow just after the system check, go through and find the setting that says door lock or something, setting should be on ' indicators and horn ' or something like that. Just put it on indicators.
    04 VZ SV6 A5
    Feb 2010
    Supercharged VU SS
    Feb 2006
    The Shire
    Quote Originally Posted by VZ_commo91 View Post
    nah thats the normal locking with the horn setup,
    by the sounds of it, in this case its 3 short beeps, which means something is not shut properly
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by Slipper View Post
    back right actuator gone hope they arent too expensive
    If it's an intermittent problem. Rip it out and clean it with some Contact Cleaner. Has worked for me in the past.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Mine is/was the rear passenger door and only seems to play up if the car has been left out in the rain, maybe water is getting inside that particular door actuator.
    But when it does happen I just activate the door opening and closing a couple of times and usually fixes itself.
  1. stop that beep beep beep digital dash
    By murphy_51 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-09-2010, 07:04 PM
  2. BEEP BEEP BEEP - Bulb sensor keeps going off
    By anonymousmoose in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-12-2009, 03:28 PM
  3. beep with central locking
    By fly350 in forum Electrical Wiring / Questions
    Last Post: 20-05-2009, 11:30 PM
  4. Horns! beep beep ....
    By rcnugget in forum General
    Last Post: 05-11-2008, 09:10 AM
  5. easy way to make my car beep when locking
    By vyaw2003 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2006, 09:14 PM
