Results 1 to 13 of 13
Thread: locking problem ( not what you might think )
    2006 VZ commodore Acclaim
    Jan 2007
    Ipswich QLD :(
    Default locking problem ( not what you might think )
    So I got home from work, with my normal key. Tried to lock the car ( which was locking perfectly all day I might add ) Tried to lock the car... Nothing, boot wouldn't work, unlock wouldn't work... So I started the car with the key let is sit, turned it off... Still nothing. So I grab the other key.
    NOTHING! I'm getting quite pissed now...
    Went for a drive with the original key, get home, and BOTH keys work... I might also add the Engine fuse was also really hot. where as the rest were the same temp...
    So now its locking fine again, I always thought it was the key, But now I'm thinking it could be more.
    Any help ? suggestions ? something I can do to fix it ?
    VZ Ute
    Feb 2011
    Perth -Rockingham-, WA
    Where you holding your tounge the right way LOL? Are both your keys in good condition the rubber button bit specifically? Also i have found that sometimes if i don't point the key at the car it doesn't quite work properly
    VZ 3.6lt V6
    Would have bought a V8 but I wanted to go FAST
    VZ Executive
    Apr 2007
    Hi,
    Sometimes the Key signal is being drowned out by something broardcasting on close frequency, i.e. say a fluro light breaking down or similar. I have had my key not work in a public car park in a particular spot. Elsewere in the carpark - no problems.
    Just a thought.
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Ive heard that all vz's have a key problem, sometimes it just doesn't work.
    Drives ya mad when you cant open the car, then you have to use the key and suffer the alarm at the most inconvenient time.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    WL Caprice
    Mar 2011
    I've seen dry joints in the pcb inside the keys. Sounds dumb, but if the key isn't working stick it in the freezer for a few hours. That was the advice from RACQ to one of the guys I work with.
    The final solution was a new key - blanks can be purchased on line and programmed by Holden or other key places.
    Jan 2007
    Ipswich QLD :(
    Quote Originally Posted by CapriciousWL View Post
    But the problem is both keys wouldn't work, then all of a sudden they Both would after a drive... I'm beginning to think it's something to do with the car NOT the key.
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Most likely the battery in the key transponder on the way out. Not user-serviceable; take it in for servicing.
    High frequency broadcasting apparatus, like TV/radio transmitters, can block signals to and from immobilisers e.g. the tower on Mount Wellington in Hobart Tasmania will play havoc with remotes. Best to manually lock the car up there or risk an inconveniencing call-out to RACT.
    Digital set top boxes for TVs have also been speculated as culprits though we have three in our large house and no evidence they are interfering.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VZ Exec Wagon
    Apr 2009
    Manly, NSW
    Quote Originally Posted by CRUSTIN View Post
    I'll + 1 on that.
    My VZ does it on average once every 2 months or so.
    And can be anywhere to do. Even in the middle of nowhere.
    Even better when you have to use the key and the alarm goes off at 3am
    Jan 2007
    Ipswich QLD :(
    Quote Originally Posted by Little Red VZ Go-Kart View Post
    It has done it when I used to live in the sticks where I was on full solar power, with little to no service with mobile/TV.
    Could it be something in the car that could do it ? Perhaps it has never been the key, but been the car the whole time ?
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    mine does it occasionally, and btw, the keys are serviceable, pry it open, change the battery and super glue it back together, just make sure you put a blob of blue tack against the connection and battery, so it is a solid connection. done it before with a lazy key and it fixed it. but just make sure you have a spare, because i take no responsibility in what others do
    Spoken by a true member of The Committee
    WL Caprice
    Jun 2011
    i had this problem the other night in the rain and tried the spare key as well. Neither would work and the centre dash lights would not trun off. This would suggest that this is not a key problem rather an electrical problem. In my frustration so the battery doesnt die overnight, i disconnected the battery terminals so i can start the car up in the morning. i re attahced them to see if there was any change and the keys suddenly worked.
    Jan 2007
    Ipswich QLD :(
    Quote Originally Posted by johncaprice View Post
    Awesome feature with the VZ, If say the radio, or interior light is left on for 1 hour with out touching anything with the car, it will shut off everything in order to save power... I leave mine on all the time by accident, and its always off by the time I get back to the car. But the switch is in the on position.
    An update on this... My keys have not done it since that day....
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Yes the keys are self servicable, as stated above. Follow the guide in the How-To section on VS key.
    All this info that has been posted doesn't solve the very hot engine fuse issue, I wonder what would be causing that.
  1. VS Central locking problem
    By wickann15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2010, 12:35 PM
  2. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  3. VT2 Central Locking Problem
    By Stretcher Bearer in forum Electrical Wiring / Questions
    Last Post: 04-03-2007, 11:19 PM
  4. Central Locking Problem
    By Vs_sharlene in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 08:57 PM
