Results 1 to 7 of 7
Thread: Mace Manifold Insulator
    VZ Exec Wagon
    Apr 2009
    Manly, NSW
    Default Mace Manifold Insulator
    Hay guys im about to do a spark plug change on my v6 VZ.
    From what iv red, the stock manifold gasket is paper thin and usually brakes or gets damaged when you take it off.
    Now Mace do a 12mm machined insulator that you can use over and over, plus it runs cooler and a little extra gain in rpm
    http://www.maceengineering.com.au/ep...Products/MI603
    Iv looked into it a bit and a new stock gasket is about $60 or so,
    and the Mace insulator $150. It would pay for itself after the 2nd spark plug change.
    My questions are.
    Is it worth it?
    Does anyone else have 1 running now and does it improve anything at all?
    Brendan
    Phyco's Avatar
    Phyco is offline Alloytec and Proud
    06 VZ Acclaim Sedan
    Mar 2009
    WA
    Quote Originally Posted by Brenah View Post
    That is if you still have the car after another 120,000Ks :P
    I bought one, noticed a slight difference. I will be buying a CPR6 Manifold (eventually) so then it will no longer be necessary
    -My VZ Acclaim- feat. ASR Audio Sound/Lighting and Various Other Mods
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    VZ SV6 155.1RWKW
    Jun 2010
    noticeable difference when i put mine on, more bottom end, and the plenum stays cool as.
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Agreed, my manifold in much cooler. Debatable whether that would affect power much, but the insulator isn't a gasket, they give gasket maker in a tube with it. We use it at work, good stuff. The insulator is just an insulator, not a gasket.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    VZ Exec Wagon
    Apr 2009
    Manly, NSW
    VZ Exec Wagon
    Apr 2009
    Manly, NSW
    Quote Originally Posted by CRUSTIN View Post
    Whats gasket marker?
  1. Mace manifold insulator & plenum spacer
    By muzzz89 in forum V6 Development And Modification
    Last Post: 31-01-2012, 10:50 AM
  2. MACE Manifold Insulator & Plenum Spacer Review
    By HamaTime™ in forum Mace Engineering
    Last Post: 26-01-2012, 03:38 PM
  3. SIDI Mace Manifold Insulator
    By LachieSV6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-06-2011, 01:55 PM
  4. Installing Mace air intake manifold insulator
    By EnFoRcEr_001 in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2009, 03:46 PM
  5. Vs Manifold Insulator
    By mcvk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2008, 10:21 AM
