Results 1 to 11 of 11
Thread: HELP! Crankshaft Pulley.
    VZ SV6 155.1RWKW
    Jun 2010
    Default HELP! Crankshaft Pulley.
    Just bought the powerbond pbk007 pulley set from ttt performance engineering and cant get the crankshaft pulley off to replace it with the new underdrive one.
    The pulley bolt was supposed to be the hard part but it undid with a little effort with a torque wrench but there is no way the pulley is moving. I tried using a 3 claw pulley puller and instead the puller just bent and broke after many attempts.
    Going to go buy a new puller (hopefully somewhat better) but how the hell can i get the thing off? any suggestions?
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Use a light hammer, and try to use quick taps on the surface of the pully, should break the rust off it. By the way, underdrive pulley's are scams.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Need a better puller?
    An underdrive pulley is a scam? Hows that when it does what it claims to do? It reduces the load of the accessories on the crank. It may not give huge increases in power but it does give some.
    Silver Certified.
    VZ SV6 155.1RWKW
    Jun 2010
    Managed to get hold of a better puller and got the pulley off! Before you say its the "Placebo effect" the car drives with less effort and revs freer, I'm not saying it gave me astronomical gains , but it has done something noticeable.
    By the way, any idea on how to stop the crankshaft from turning when tightening the bolt on the last couple threads? The new pulley is solid so I can't jam anything in it, its an auto too.
    carless for now
    Feb 2007
    perth,Western Australia
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by treyflip View Post
    So you are driving around with a loose pulley? Might be 100% underdriven shortly.
    VY SS
    Jun 2006
    Albany
    apparently you remove the starter motor and use either a flywheel locking tool or just wedge a big screwdriver into the ring gear to stop the motor turning.
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Put Trans into Park & apply the handbrake hard on. That should be enough to be able to torque up the bolt. (about 200ft/lb I reckon is enough).
    VY SS
    Jun 2006
    Albany
    handbrake will only stop the rear wheels and putting it in park will only stop everything from the gearbox back, the torque converter will still allow the engine to turn.
    2006 VZ SV6
    Jan 2009
    VZ S 175 Ute
    Nov 2010
    Trey, i have reasons for saying that, I've explained it before, but i cant be bothered anymore. Just believe that the biggest difference you feel, is what you think you feel.
  1. crankshaft pulley bolt
    By VTPREDATOR in forum LSx Development and Modification
    Last Post: 12-08-2010, 12:38 AM
  2. crankshaft pulley
    By King_berald in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-01-2009, 06:53 PM
  3. Crankshaft pulley ???
    By mattakaspeeedy in forum V8 Development and Modification
    Last Post: 01-11-2008, 04:13 PM
  4. Loose crankshaft pulley?
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2005, 03:44 PM
  5. Crankshaft Pulley Bolt
    By sulo2blue in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 12:26 PM
