Results 1 to 11 of 11
Thread: VZ Ute Issues
    VY UTE
    Apr 2011
    brisbane
    Default VZ Ute Issues
    Hi all, hoping for some useful info relating to a series of issues on VZ ute. Control panel has only in the last 2 weeks been flashing up "check powertrain" and yesterday its also flashing up "check oil". I have read and see that "check powertrain" seems to be a common fault and various fixes have been O2 sensors replaced and or software upgrades, which is it?
    As for the oil the oil is regularly checked and OK. The ute only has 70k on it so not tied or over worked. Any constructive help appreciated.
    Cheers Chris.
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Any mods performed?
    VY UTE
    Apr 2011
    brisbane
    No mods all stock, was there ever a recall where they (holden) rolled out a software upgrade?????
    VZ A4 Saloon
    Nov 2010
    Might like to check the oil pressure sender. It may be leaking.
    It's located on the oil filter body.
    Thesickness86's Avatar
    Thesickness86 is offline Thesickness86
    08 Ve ute
    Mar 2011
    I thinks it's the 'oil pressure sensor' not sender. Mine was faulty and Ive heard it's fairly common.
    Life tastes sweeter when it's wrapped in debauchery!
    VZ Crewman
    Jun 2011
    St Marys
    Got the same problem on my vz crewman, today i change the plugs and oil switch and when i started it, it idled rougher than before. I did notice a dogey looking coil module so i changed that, During the process i diconected the battery and now when i star the car it idles good but when i rev the car nothing wont rev at all. Anyone know what the problem is ,,, Help me before i put a match to it,,, and the (powertrain) msg still there, and the (check oil) still comeing on...
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    get someone to check the codes?
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    lol +1 oil pressure SENSOR will be leaking into the connector..
    pull it off and look inside MALE side and it will be wet needing a new sensor
    if not wet possible oilpressure issue
    either way PERSONALLY i would check code is set for the oil pressure sensor but if the connector MALE is wet with oil its gone man!~
    VZ 3.6 S
    Oct 2009
    @ mikabeja,
    After i changed the plugs in my V6 it was rough as guts...My solution: do up the spark plugs to within 16Nm 22Nm tightness (torque wrench?) then it will cause the engine to run fine. If they are overtight or not tight enough it runs rough...i dont know why but it does...
    vz thunder s
    Jul 2011
    boronia heights qld
    hi had same problem with vz thunder s ute. to answer your questions NO there was not a recall but i think they (HOLDEN) should have because it can be dangerous when you are traveling at 100 kmh and it comes on it slows the car to 15 kmh so quick it is scary. and the only way to fix it is to take back to holden to clear the fault and if they can't fix it they recommend replacing the computer.
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by craig wilson View Post
    So what was the fault you are referring to?
    Should Holden do a recall because the ECU detects a fault?
  1. Air Con issues
    By QldKev in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2010, 05:47 PM
  2. VX s6 issues.
    By D_BLOCK in forum Tuning
    Last Post: 25-08-2010, 09:44 PM
  3. VR issues
    By ben_046 in forum Electrical Wiring / Questions
    Last Post: 13-05-2010, 05:12 PM
  4. VY Oil Issues
    By Dr HaxZaw in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-05-2010, 10:50 PM
  5. VZ issues
    By sxcmonkey in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-03-2009, 02:21 PM
