hey, just wondering if anyone else has had oil leak problems on their alloytec? im getting a bit of oil leaking around what look like to be cam position sensors. if anyone has had this problem, what were the costs in replacing these seals?
usually the timing cover leaks, but ahve seen a couple leak from the seals, they are about $15 a seal and are easy to change yourself if your competant
i know ur thoughts dave, just i want to do the cheaper seals before replacing a pump, because the seals are deff leaking anyways
I have some brand new genuine seals if you cant find any.
had some lying around, working at a holden dealership has its perks.
PM me if you want to purchase and i will post them to you.
