Hey guys.
VZ Executive with SL and 19's (will be here in a week) I was wondering if I'll possibly need to get a camber kit? Or SHOULD a full wheel alignment (adjusting rear TOE etc...) from Pedders fix any issue of camber wear if there will be one?
Anyone else had issues with 19's + SL? Did you end up just getting a 4 wheel alignment or a camber kit?
Vy/Vz's already have Heel-toe adjustments, so you shouldn't even need one unless you're running like 20mm from the ground lol. I'm around 7.5cm from the ground, and my wheels are pretty much straight (SLIGHTLY) cambered but it's enough to chew the inside.
But on to the question, if you're getting new wheels + tyres get them to do a front/rear wheel alignment, just so the fronts dont chew out from trying to steer one way, and the rears getting lousy.
I have 18"s with SSL. But picking up 20's tomorrow![]()
I have 19's with Ultralows and the rear has a slight negative camber but other than that no issues.
sl's are like stock height haha i'm rockin sssl's with 18 inch vy ss rims and my camber is huge. but i haven't been bothered to get an allignment for the rear camber kit and wheels themselve yet so i'm mauling tyresbut to actually answer the question, you wont know till you pick it up.
livin' the low life.
Ah ok, I might have SSL, not too sure (was lowered when I bought the car). I'll go to Pedders when my wheels arrive and just get a 4 wheel alignment for $120.![]()
