Results 1 to 8 of 8
Thread: sv6 manual question
    VZ SV6
    Jul 2010
    Default sv6 manual question
    quick question?
    when giving it a go or when at the track, what is a safe rpm level to shift?
    and also the optimum rpm level before you start losing power?
    cheers
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    every driver is different, it depends how fluent you are with the change itself and a few other factors like clutch setup, tyres etc.
    As for losing power? You wont lose power high in the rpm, max torque is at 3200 rpm so you wont get more acceleration then what you do at 3200.
    If your slow through the gears, change higher into the red, if your quick just before or right on the red
    Life starts at 200km/h
    Dz811's Avatar
    Dz811 is offline Just some p-plater
    VZ SV6 M6
    Sep 2009
    Quote Originally Posted by impulsive View Post
    That's not entirely true, in (very basic) terms, torque x Revs = HP.
    Generally providing your clutch is in good order and changes are smooth, the higher rpm u can change, the better. So you might as well max it out...
    Beware of overheating with commodores under high load at the track though not really built for racing purposes, so brake fade and prolonged sessions at high rpm can see your temperature gauge shoot up.
    otherwise good luck
    Quote Originally Posted by QuickVRII95 View Post
    I Outsmart Defence Force Psychologists... My IQ "IS" Also Over 165.....
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by Dz811 View Post
    i think you missed the point i was getting at, nevermind...
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Dz811's Avatar
    VZ SV6 M6
    Sep 2009
    Don't be dumb... I said very basic terms, obviously there's more to it... but the math is the same.
    IF: at 2000rpm you make 300NM
    AND: at 4000rpm you are still making exactly 300NM
    Your "HP" output will be exactly double at 4000rpm... make sense?
    unfortunately torque is not linear, so neither is the power output. But, more RPM means more power (as long as there's no major drop in torque)
    VZ SV6
    Jul 2010
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    i change just before max RPM. Will give you a more fluent change
  1. Vr Manual Question
    By GunnaBeSumthingVP in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 07:16 PM
  2. Vs manual question
    By k-loww in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2010, 04:51 PM
  3. 5.0L manual question
    By wilko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2008, 06:16 PM
  4. vn ss manual question
    By anothervn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2008, 02:37 PM
  5. VX manual question
    By MaxVXS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2006, 12:33 PM
