Results 1 to 3 of 3
Thread: Broken glove box handle
    tHe_sTiG's Avatar
    tHe_sTiG is offline <--- Want a ride?
    VZ Executive
    Jan 2010
    Saudi Arabia
    Default Broken glove box handle
    Hi guys,
    Just wondering if anyone knows how to replace the glove box handle in a VZ; the opening mechanism is broken. A new one from Holden costs $27, for labour they'll charge me a further $45. The labour charge is a rip-off in my opinion.
    Would replacing the handle be as easy as a DIY job? Is there anyone out there with a guide?
    Help would be much appreciated
    Thanks
    The only Exec in Saudi that's now properly badged!
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    well i left thought someone would have a link or sumthin!~
    anyways its not too hard just pull lower trim off (under glove box if its got it)
    pull glove box out (screws around it with door open and 2-3? underneath)
    hold firmly and yank on glove box but dont pull all the way out
    undo electrical connections from glove box
    remove glove box from car to a bench
    then theres screws on the inside of the door that undo allowing the case (outer panel) to pop off
    then replace whats shagged....
    now like i said i dont remember exactly but you could do it yourself vy vz ve very similar (except latches inside panelling)
    if you can get the glove box out then you can probably see how to pull it apart from there....
    tHe_sTiG's Avatar
    VZ Executive
    Jan 2010
    Saudi Arabia
    Quote Originally Posted by db_notso View Post
    Thanks for the help. Seems pretty simple enough, only its the wiring that's worrying me. Car is due for service within a month, I can let them have a look at it then.
  1. [VZ] Broken VZ glove box handle
    By tHe_sTiG in forum Holden Commodore How-To's
    Last Post: 07-05-2011, 07:50 PM
  2. VS Glove Box Broken ?
    By aussie7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2011, 08:30 AM
  3. Broken Glove box
    By jamex101 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-07-2010, 12:31 AM
  4. Broken Glove Compartment
    By Knighty43 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2010, 12:10 AM
  5. Broken Glove Box in the VX
    By Chris The Slayer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-06-2008, 07:19 PM
Tags for this Thread
