hey guys my car jus fkd up on me 06 vz exec i was driving didnt have a problem parked the car started the car bak petrol indicator kept coming up low on fuel and the gage was at red i filled up 60 buks still did the same thing keeps beepipng and the gagae is on red came home reset the ecu didnt help and as i reved it the exhaust was bakfiring wat can be the cause neeed urgent help please
Not registering on the dash + backfiring might be a leak somewhere? Does it piss fuel out anywhere under the hood?
ok im not sure bout registiring this is excatly wat its doing i start the car the fuel indicator comes up beeping and the petrol idle is sitting on empty...i was driving to work last nite hit the freeway the idle went up to about quater tank showed 160k left to empty on the trip pulled up to servo filled the tank up full jumped bak in the car hit the freeway than it droped bak down to zero...i think its not registiring im not to sure this my first vz first time im entering the new holden scene if it was old ones id noe like the back of my head but new ones dont know anything
have u played with any elctrics in the car eg new headunit?
have you done anything under the bonnet?
Mods example pod filter.
have u recently changed spark plugs?
Start step by step, Have a look at all your fuses footwell and under the bonnet.
Let us know how u go.
Dave
Check out My WL CAPRICE
http://forums.justcommodores.com.au/...price-l-k.html
Maybe the sensor on the float in the petrol tank is stuffed?
Ronald Reagan (1986)
Maybe long shot, but unrelated?
Or possibly the harness to the pump is intermittent and is giving low pressure and no reading to the dash. Or even check the wiring from the ECU to the tank and look for away wearing or fraying of the wires.
Sounds like you have an electrical fault in the dash and/or the sender unit in the tank... take the car to an Auto Electrician/Mechanic that can hook it up to a tech2 and check for any faults.
On another point... Punctuation/grammar/sentences... have you ever heard of these things???
Has anyone considered the two may not be related but rather coincidence?
That aside the only thing I can think of that isnt mentioned above is bad fuel, the possibility there is water in the fuel, or sludge could make inaccurate readings on the gauge, and cause back firing.
It is a long shot though.
But my personal advice is go and see a mechanic, Holden would be an ok bet, they can hook the car up to the computer, and if your lucky it may give the exact reason for it having those problems.
On a final note, I am not a grammar Nazi, but reading your posts take alot of effort. Please work on the grammar and spelling.
yeh well this exactly wat happened just decided not to work i took the positive battery terminal off put it back on soo ecu can reset itself nothing... i have not touched no electrics or any other system in the car as its still fairly new only on 90xxxkms..just recently it has also decided to work on and off sometimes wen im cruising down the freeway it rises up to bout quarter tank stays there for bout 10 minutes not even than drops back down to zero...the cars still got warranty 3 years left i booked it in for holden but there flat out till the 30th and i cant wait that long work and all so i was just asking if it was something small easy fix id just do it but looks like gotta wait for holden thanx again guys
found the problem too it to holden today results are ecu needs software update (REPROGRAMING) for fuel gauge....center exhaust muffler needs to be changed.. and also the spark plugss bit costly though![]()
