Hi, i have a missfire issue with my calais. It started at easter when I was passing a truck on the highway, I gave it a boot full around the truck and the check drive chain warning came up, and the engine started to miss realy bad. I pulled over at the next servo and turned the engine off, and when I restarted it the miss was gone.
Up untill this week the car has not missed a beat, but now if I "give it a bootfull" it starts to miss again untill I turn the engine off, then when I restart it is fine again. I also have niticed a slight missfire when the engine is under load (up hills ect) Anyone had the same problem? or know what is wrong? thanks
get your injectors properly cleaned...
i had this issue and changed plugs and coils and found it was dirty injectors
ok thanks, i was thinking plugs, coil packs ect. Did you have the check drive chain warning come on aswell?? that worries me a bit.
yep... scan tool even showed misfire on cyl 3
ok thanks for all your help mate, there is a mechanic in the shed next door to my work, will go and have a chat to him tomoz, cheers
