Results 1 to 15 of 15
Thread: Removing Front Grill VZ CALAIS 2005
    Calais 2005 VZ V6
    Dec 2008
    Cool Removing Front Grill VZ CALAIS 2005
    Anyone help need to get behind the front grill between the headlights can I get the grill off without haveing to remove the whole front bumper if so can someone pic or explain how
    Crazy2009
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    should be some + screws holding it on the front bar, then it should slide out of place
    Life starts at 200km/h
    dijm8's Avatar
    dijm8 is online now What You Looking At
    VZ SS LS3
    Jun 2006
    Calais 2005 VZ V6
    Dec 2008
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Calais 2005 VZ V6
    Dec 2008
    did that had 3 screws undid them but that leads to take the whole bumper off not just the grill well it does on my calais
    Calais 2005 VZ V6
    Dec 2008
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    I don't think the Calais grille is any different in its method of retention to the other variants. It should be held in by three screws along the top and three lugs on the bottom which are a firm fit into slots in the bumper. It definitely isn't part of the whole bumper assembly as I'm sure I've seen it listed as a separate part.
    If I'm right, you undo the screws then pull the grille up firmly. Those tabs can sometimes be a very firm fit.
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Gees, one bloody screw. It was three on the VY's. I wonder how much they saved per car with that change?
    Anyway, to the OP, dijm8's post should answer all your questions. One screw and yank it.
    Calais 2005 VZ V6
    Dec 2008
    Default Grilll Removal
    Well we all got it right and got it wrong what a S.O.B of a job have attached photos basically you have to remove all 3 screws lift bonnet located just in front of radiator There are 2 lugs holding grill in place left and right attached to bumper at top and same at the bottom hopefully pics help you locate The 2 lugs at bottom are a b...h to get at and have to be depressed in a forward motion to get them unclipped.
    But thanks to all without your help would never have gotten this crapy bit of plastic out
    Cheers guys
    Attached Thumbnails Attached Thumbnails Removing Front Grill VZ CALAIS 2005-dscn0307.jpg   Removing Front Grill VZ CALAIS 2005-dscn0311.jpg   Removing Front Grill VZ CALAIS 2005-dscn0305.jpg   Removing Front Grill VZ CALAIS 2005-dscn0309.jpg   Removing Front Grill VZ CALAIS 2005-dscn0306.jpg   Removing Front Grill VZ CALAIS 2005-dscn0310.jpg
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    That's surprising about the lower tabs. I could see that the grille had two upper locating points as well as the screw from the photo in post #9, but I'm surprised that you had to actually get in behind the lower tabs and push them forward to release them. Other models just pull out, though they are sometimes a bit stiff.
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    you shouldnt of have to remove all 3 screws just the 1...maybe it was the first time being removed hence being tuff to remove....they usually just pop straight out no force at all
    Calais 2005 VZ V6
    Dec 2008
    The clips definatley had clips on the upper and lower lugs holding them in place
  15. #15
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    What did you replace it with? Please don't say a Chev grill... (although, I think the Chev grills to suit the Calais are actually pretty hard to get hold of)
  1. Troys old 2005 VZ S Ute. Calais front, SS sides
    By Troy711 in forum VY - VZ - WK - WL - V2
    Last Post: 15-11-2010, 10:47 PM
  2. Vr/s Senator Front Bar + Grill *genuine* / Vt Calais Front Bar + Chrome Grilles
    By petezor in forum Parts And Other Items For Sale
    Last Post: 02-02-2008, 11:42 AM
  3. vt calais front grill
    By vts98matty in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-04-2006, 03:30 PM
  4. Perth WA - VN Calais Front Grill
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2005, 11:40 PM
