Results 1 to 7 of 7
Thread: harmonic balancer removal what puller????? HELP!!
    VL Calais Manual, VZ SV6 Manual
    May 2011
    Default harmonic balancer removal what puller????? HELP!!
    hey guys im doing a underdrive balancer and belt kit on my sv6 ive got everything off cracked the balancer bolt but i cant seem to get the balancer off... i have tryed using 2 different types of pullers but as i get tension the arms just slip out... ive tryed grabbing it from the outside and tryed from the inside.. also tryed from the inside but grabbing the outter edges... has anyone removed one of thease before on their alloytec and have any useful hints for me or even what type of puller they used... thanks!!!
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    you grab the inside ring (closest to bolt) with a large puller (16mm minimum bolt in puller as a guide only)
    if the pullers claws arent in good condition they will slip,
    i have had to file them flat on the odd occasion where they bite onto the pulley so they dont slip
    and hold it really tight as you wind the bolt in so it grabs better...
    otherwise i dont know why it wouldnt work for you as i have done it this way many times...
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    GGT tools part number for the Alloytec-specific puller is GGT180.
    Be warned though, they're not cheap.
    Need a part number? PM me.
    Luke.
    May 2011
    wholey f**k thats expensive for a puller... my mate who is a fully qualifyed diesel mechanic is gunna come around tomoz after work and have a go.. he has a few different pullers he is going to bring with him, so i think ill give that a try first lol
    Sep 2010
    Mulgrave, VIC.
    Very good idea, I wouldn't fork that much out for what might be something you use only once.
    Good luck
    Luke.
    May 2011
    got it off got the new powerbond one on!!! i used the smallest puller you could buy from repco and got it off in a couple of seconds!!
    VZ SV6 155.1RWKW
    Jun 2010
    i did mine a couple months ago, the crankshaft bolt was easy but we snapped an arm on the pulley puller when trying to get the stock balancer off. pain in the ass but was worth it!
  1. Harmonic Balancer removal
    By AqaumarineVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2010, 09:39 AM
  2. Harmonic Balancer Puller
    By hemi01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2009, 04:42 PM
  3. Harmonic Balancer removal?
    By VHSLX3300 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2008, 10:22 PM
  4. harmonic balancer puller
    By Gillz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2007, 06:10 PM
  5. Harmonic Balancer Removal
    By andrew77 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-07-2005, 10:43 PM
