hey all just wondering whats a camber kit roughly worth or is there another way of straightening the wheels
Are you fitting yourslef? just a quick serch on ebay 100-500 to your door..
If you don't have the toe control links. You will need a 4 point kit.
what are the toe control links? haha i just got told a need a camber kit to pull the back wheels in i dont really know much about them so any info would be much appreciated, thanks
They are links added to the rear suspension on VX2 and later Commo's. Although I think they were omitted on wagons and utes.
Don't fit them yourself. They are a major pain in the arse.
Get them fitted professionally..
I do the SuperPro 4 point kit for $185 posted.
I agree they are an absolute pain to fit plus you need to get the angles right so need a wheel alignment after fitting anyway. , but VZ's shouldnt need them. I thought that on the VY series 2 & on, they had corrected the majority of the Rear Wheel Negative camber issues & the wheels look reasonably straight when you look at the rear of any VZ on the road..
The lower you go the more negative camber you create.
i bought my ute lowered so i dunno what its got in it, i know its got the FE2 suspension but thats it haha, and yeah id get it done professionally cos id be too scared to #### it up lol, does a normal wheel and tyre centre like bridgestone sell and install camber kits? and if so would it be the easiest way or cheaper to buy one off ebay and then get them to install it?
Your camber is probably within spec if you have FE2.
Do you have abnormal tyre wear?
yeah the inner edges are bald but the outside edges are nearly new, its a fairly noticable camber, ill post a pic up tomorrow to show how it looks, and like i said i dunno if its been aftermarket lowered or not haha
