Results 1 to 2 of 2
Thread: VZ Timing out
    Vz ute
    May 2009
    Default VZ Timing out
    car starts and runs fine but about 5 secs after you start the engine it cuts out. seems like an immobiliser issue, any info would help, its an alloytech
    2006 VZ commodore Acclaim
    Jan 2007
    Ipswich QLD :(
    One thing to check, when you start the car, see if that red light is still flashing on the dash that shows if the immobilizer is active. If it is on when its started ( mines done it a few times ) could be a key problem.
  1. Timing belt to Timing gear's ?????
    By MMH84D in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2009, 11:28 PM
  2. Just where does the timing need to sit on the 308?
    By Paiste402 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-12-2008, 05:31 PM
  3. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  4. Timing
    By krisjanik in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-11-2006, 09:21 PM
  5. timing
    By vn series 1 owner in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-06-2006, 07:50 PM
