hey guys
i currently have sv6 tail lights and i want to know if the lens cover can be removed? cause i wanna spray the lens on the inside to make them look like ss ones
so i pre much wanna know if thhey can be taken off and how
cheers boys![]()
personally, i wouldnt bother... too much effort, plus if i see you i will run into you and say i could see your lights, you would get defected and have to fix my car at the same time..
On a different level, it can be done, how, i dont know.. but i know it can.. On a different not again, if u like the SS ones, buy them instead!!
Life starts at 200km/h
Delete post.
Buy the SS ones I did for the sake they, they are illegal and as Impulsive said if someone rear ends you, you mostly likely will not be covered.
I've seen some dogey looking spray jobs on them, also if you don't do it right they will flake and look worse, but people believe putting on a few coats of clear prevents this.
Bottom line Go the SS taillights *see my ride thread if you like below* visit your local wreckers ya might get a pair for cheaper
