Hey i no this might be stupid question but is there a way to adjust the idermediate speed of the wipers or not???
Pretty sure that's why automatic wipers were invented... But yea no idea...sorry.
If you mean 'intermittance' then probably no. Although there are aftermarket kits you can install.
Higher spec models have variable speeds. Which probably means changing BCM, stalk etc.
on the vz, theres an option if you still have your stock head unit in your options menu on your clusters which you can turn off and on, which is the wipers speed based on how fast your drive. i used to use it but now i have upgraded to an aftermarket head unit so ive lost those options
HSV Clubsport VZ Body Conversion - Mace CAI - 2.5" Walker Single Catback - Red Neons - Custom Dash
