alright i wana do this 2 hole mod... this might sound stupid but i have no idea where to get this monaro shroud from which u apparently need for it to work effectivly??? could anyone fill me in on where is best place to get one or if it is needed or if there is alternative??
cheers
go to holden, and just tell them. btw, u dont need the shroud, just use pvc piping, works just the same, just paint them black, it will look stock
aw sweet cheers
but dont u need the Mcai shroud to be there so it seprates the two holes from the warm air in the engine bay? or do u keep that orignal 90' duct there and put the new hole next to with PVC piping casue all other method or doing this mod say u need the MCAI shroud??
If you are so concerned about warm air (warmist?) do the mod in the picture below or go solar.
i never bothered with the two hole mod, just fitted a monaro air box bottom... $35 later
Life starts at 200km/h
na, just put in 2 90mm pvc pipes painted black facing forward, once u get moving, the air underneath the bonnet will be sucked downwards and replaced with cool air anyways
Cheers for that mate give it a go over the weekend
There's a nice increase in Torque from 3000rpm. Not a shitload but noticable.
Overtaking a truck at 60kmh. Foot flat down. drops to 2nd and wheel spins past the truck.
You can hear a slight sucking noise too
Never use to loose traction like that.![]()
Well I did the 2 hole mod yesterday an the verdict very impressed!!! Don't think it gave me much in terms of power gains but defs increase in torque past 3000... And great sound!! Recommend this mod over a $$300 ss reduction kit...!!
Cheers for the help boys
fitted mcai last weekend best move ever sounds great performance is up fuel economy is down fantastic for $35 paid over $200 for vs otr cai a few years ago this performs better
Hi guys,
Long time reader but new member on here. Iv been looking at an otr induction but they costly as all hell. Im liking the sound of the mod you guys are talking about. Can anyone fill me in on the details start to finish? btw i drive a vz ss ute if that matters.
Cheers guys.
search 2 hole mod in google, there is a comprehensive guide on how to do it. for more cold air, go to holden and buy what is called a 'monaro cold air intake shroud', which esentially allows you to block the whole front of the airbox from the warm engine bay heat. heard good things with the v8's, however, not as much increase as an OTR. and when you do buy an OTR, buy a good one like the GM Ramjet, which can be used with a maf, or another one called DUSPEED, which looks shmick.
