Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Reaper
Thread: having to turn wheel more round corners
    VZ Lumina
    Mar 2011
    Erskineville
    Default having to turn wheel more round corners
    This really has me confused. Just got my vz lumina lowered slightly by pedders. new springs and shocks though not much lower than the stock. I considered the steering prior quite firm and really liked it. now it is not as firm and find myself having to turn the wheel quite alot more to get around corners. i took it back for them to have a look at but couldn't see a problem. today i drove a vs and a ve (would love to jump in a stock lumina right now) and realized my steering is definately requires more turning. I have been trolling the web a while looking for an answer having checked tyre pressures and looking for leaks. i hopeing someone might point me in the right direction.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by langoose13 View Post
    Well there is your problem right there.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    WL Caprice & VQ Stato
    Feb 2011
    Seaford
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Reaper
    Couldn't agree more.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    front castor and camber plays a major role in steering effort, chances are your wheel alignment settings were changed after the spring install...
    have a wheel alignment check done and see if its out of spec
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    I reckon it may be a poor wheel alignment, or the requirement for one if you didnt have it done
    Life starts at 200km/h
    VZ Lumina
    Mar 2011
    Erskineville
    thanks all, had the wheel alignment checked and is ok. feel like the castor arm adjustment with the new springs must be what has made the difference. there is a bit of play in the rack but the difference i noticed is from before and after the lowering. Is there a way a can firm it up again. i always thought lowering would make the steering firmer, at least that was the case with my vs. granted it is an acclaim and came down alot further.
    the vz really isn't nice to take through corners at the moment.
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    I have adjustable castor radius rod bushes on mine.
    Currently they are set at maximum positive castor. This firms up the steering a bit. However, under load around corners it makes the wheel want to self centre too much. Will be changing to a more stock setting in future.
    It's all a compromise. And based on what the driver wants.
    Supply the alignment settings for us to look at.
  1. vu tyres rubbing in corners
    By dragon91 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2011, 09:59 AM
  2. VR Stalling around corners
    By Rob&Krisseh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2011, 08:03 PM
  3. Clicking when i turn corners?
    By MGNick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-03-2010, 11:28 AM
  4. Clicking when i turn the wheel
    By jakewaze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2008, 05:04 PM
  5. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
