Hi,
Recently purchased a 2005 Holden VZ Lumina, it has a fitted security alarm system.
When you press 'Lock' on the wireless remote, the indicators flash then the horn sounds about 3-6 times. I read that you can lock your car without it sounding the horn by going into the Mode settings & selecting 'Indicators' not 'Indicators & Horn'
However, after selecting the 'Indicators' on the main switch board, I lock the car, all seems fine - no horn, just the indicators flash.
Start the car, turn it off, get out, press 'Lock' and the horn once again sounds.... I've tried everything I can think of.....
Any ideas or help? Would be appreciated, thanks!
are you sure its not the car telling you the door isnt shut properly? Take it back for your dealers warranty if you bought it from a dealer, otherwise have a look around the door lock underneath the door skin and hit it with some contact cleaner or wd40.
Life starts at 200km/h
Tested all the doors, boot, e.g. everything is closed and shut properly. & yeah its from a dealer, got 3years warranty. thanks for the advice!
If it was setting off the front horn and not the engine compartment horn (alarm).
Go to connector X1 terminal 17 on the BCM. Cut it. Problem solved.
