Results 1 to 4 of 4
Thread: Worries/Problems of Alloytec 190
    Barbados Mica VZ Calais
    Feb 2011
    Melbourne, AUS
    Exclamation Worries/Problems of Alloytec 190
    Hey guys i've got a few worries hoping someone can help me out, might be a lengthy one so just bare with me!
    First and the most of my worries, a couple days ago while i was removing the intake pipe off the TB to get to the water pump easier i found a decent amount of engine oil which had supposedly came through the oil breather connection on the intake pipe. I noticed the oil that was there was really dark seemed like it was from the previous service as i only serviced it 2 weeks ago and oil on the dip stick is much cleaner. Raised a few concerns though i'm not sure if the breather tube should be spitting out oil in the alloytecs or in any engine really?
    Second, i have noticed the revs on idle is not steady (watching the needle on the dash) it seems to slightly move up and down close to a miss, thought this may have been from the spark plugs so i changed them but nothing changed.
    Also i've reliased a weird noise like something electric closing and opening when slowing down to a speed hump, if i give i accelerate really lightly for a second it makes a noise as if something electric is opening guessing it may be the TB as its electric but just want to make sure
    Any help will be very much appreciated!
    Feb 2011
    Melbourne, AUS
    Dz811's Avatar
    Dz811 is offline Just some p-plater
    VZ SV6 M6
    Sep 2009
    the electric sort of clicking opening and shutting noise (if it's what i think you're talking about) is your TB. Mine has always done the same.
    It's fairly common to have oil coming through your breather pipe, though thick black oil is never a good thing, it "may" indicate lack of oil changes previously.
    Probably nothing major.
    The rough idle is generally not a good thing, but there could be a number of causes.
    a Coil breaking down, or oxygen sensors failing are probably the most common. a Good mechanic with a proper diagnostics tool should be able to plug in and work it out
    Quote Originally Posted by QuickVRII95 View Post
    I Outsmart Defence Force Psychologists... My IQ "IS" Also Over 165.....
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    Feb 2011
    Melbourne, AUS
    Thanks for your advice bud really appreciated, will stop by mechanics and get it scanned. Cheers!
  1. VT Tyre worries
    By abez24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-04-2011, 10:52 AM
  2. vz alloytec accelerating problems
    By danryan in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-02-2011, 12:55 AM
  3. vz alloytec extractor/high flow cat problems
    By create a storm in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-10-2008, 07:01 PM
  4. walkinshaw worries
    By VLACS in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-09-2005, 08:01 PM
