Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By VZ Bommodore
Thread: Fuel Vapour Smell in Adventra. Is it a VZ problem?
    VZ Adventra LX6
    Jun 2011
    Bulleen
    Default Fuel Vapour Smell in Adventra. Is it a VZ problem?
    I have a Nov 06 built Adventra LX6.
    I can't open the windows or sunroof when on the road because of the strong smell of fuel vapour that enters the cabin. It's not an exhaust smell or the smell of wet fuel but more like the smell of tanked vapours like you get at the petrol station.
    It becomes noticeable after driving for a while (eg: 20 mins), but its not easy to locate when I stop the car to sniff around. I don't notice any smell under the hood.
    I suspect it comes from around the fuel tank or related pipes, vents or hoses under the car.
    Has anyone else had this problem or know of it. The dealership can't pin it down. First up they changed the petrol cap but that hasn't fixed it. They did say they had changed a petrol tank on a regular VZ to fix the same sort of problem.
    I'm desperate to find the cause as I carry 3 kids in the car and the seals will surely deterioriate over time and start to let the smell in.
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    Most probably the seal around the fuel cap.
    After you tighten the cap on & it clicks a few times, hold the cap around the circumference & turn it just a little tighter.
    Lots of people have had that issue and this generally solves it.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Have a look at the hose that runs near the fuel filler to the charcoal canister which is behind the petrol tank .You might have to remove the plastic panel in the wheel arch to check it This hose is prone to splitting and will let fuel vapors into the cabin .
    Adventura
    Oct 2011
    Surrey Hills
    Hi BrownBro,
    I have the same problem with my Adventura NOV06 SX. Did you find the fault that was causing the petrol vapour smell?
    VZ Commodore wagon
    Oct 2011
    sydney
    had the same problem with my vz for months, finaly fixed it myself with some trusty old silicon sealant. Try removing the outer hinged locking cap via the two screws, thats where fuel vapour should be entering inside the vehicle. re-install the cap placing silicon around the hinge housing as a seal and around the screw holes before re-inserting the two screws. this should fix the problem.
  1. Fuel smell in VR ute cab - problem solved!
    By sganro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2011, 04:31 PM
  2. vapour injected gas problem
    By rumper in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-03-2011, 03:47 PM
  3. Duel Fuel To Vapour Injection LPG
    By wingwang99 in forum General Discussion
    Last Post: 22-02-2009, 10:00 PM
  4. poor quality fuel vapour hose
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-02-2007, 10:53 PM
  5. VL fuel vapour hoses. Where do they go?
    By Peterb in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2005, 07:07 AM
