hey guys just wondering what the difference between the 175kw and the 190kw alloytech engine is....?? sorry if this question has already been asked ha.
Massive difference when you drive the two
Iv driven both and you seriously appreciate the extra gear the 190 has. The 190 gearbox is also smarter. Its excellent at holding gears and gear-braking.
The 190 is also much more responsive and makes every drive a a sportier one... esp in power mode
If ur deciding... Id go the 190 and mod it if u want.. tho I havnt modded mine.
Alloytec 175kW engine has variable cam timing on the inlet valves only.
Alloytec 190kW engine has variable cam timing on both the inlet and exhaust valves.
Alloytec 190kW engine has a flapper valve within the inlet manifold, that changes the inlet manifold tract runner profile, dependant upon engine RPM/load. The 175kW Alloytec does not have this.
Early Alloytec 175kW engine has only two oxygen sensors, to comply with Euro II emission standards. The 190kW Allowtec has four (both pre & post catalytic converter), to comply with Euro III emission standards. Later model Alloytec 175kW engines also have four oxygen sensors, to comply with Euro III emission standards.
Different tranmissions & transmission ratios (both Auto & Manual).
Differing rear axle ratios (depending upon transmission fitted).
No doubt, there would be some differences to the firmware loads in the ECU, and the TCM.
Can't think of much else right now.
All the info you require is in the links below;
Holden VZ Commodore / Calais - Media Release
Good question really. Most of the info you'll be able to find in the above post. I believe the 5L40 5-speed auto is a BMW gearbox (190kw only). There's also the Aisen D173 6-speed manual transmission (190kw only), japanese gearbox. The 175kw engine comes standard with the 4L60 4-speed auto, GM gearbox.
Now that I've mentioned it, has anyone ever driven the 6-speed manual? Any opinions on it?
The only Exec in Saudi that's now properly badged!
cheers guys. mine is a 175kw auto, was wondering what the difference was and if there was any easy mods i could do to copy the 190kw. seems not. my mate at work has a VZ tonner 190kw with a 6 speed gearbox. ive driven it a few times and the only comment i can give is its a C*$# to change it into reverse.
Have had a 6 speed manual sv6, found 190/6spd pretty useless around town compared to the old 3.8 v6/5spd in terms of driveability unless ur into reving the engine. however when you get into spirited driving the new gearbox is fantastic, much smoooother gear changes, better syncro's, close gearing, seems to feel really strong, everything you'd expect from a toyota gearbox. also license losing material as you can get over 110 out of 2nd gear.....
i have a alloytech 190 with 6 speed manual and i love it, reverse is easy to get into to, and the gears are nice and close to each other so it doesnt feel like your driving a truck, feels very sporty to, i look forward to driving my ute everytime haha also around my town speed limit is 50 so id only stay in fourth gear which sits on around 1500 revs so if you wanna put your foot down youd have to change back a gear, but also i dont mind that lol and out of town on 100 sits in 6 nicely on 1800 rpm, and has enough go from cruise going up hills and what not, anyway hope i was of some assistance
Nah, weaker then piss. Put your foot down from 1st to 2nd, dump the clutch...1...2...3, locked. Slips like a slut!
Sure doesn't need a breakaway point in the drive line, the clutch wont hold enough torque to snap anything.
Originally Posted by Little Red VZ Go-Kart
1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??Originally Posted by HoldenV8
give everything a spray with wd40 wheels brakes that should fix the squeaks
Life starts at 200km/h
Yeah, i plan to weld mine to the flywheel before i get a new one.
