Results 1 to 8 of 8
Thread: Headlights/fogs are turning on when they shouldent
    VX EXECUTIVE SERIES 2
    Jan 2009
    Default Headlights/fogs are turning on when they shouldent
    Just purchased a Sv6 ute and it does the following:
    *parkers turn on no problem
    *low beam(driving lights) also turn on no problem
    BUT! when the driving lights are on and you turn on the HIGH beams...the left driving light dropps out and the right driving light/high beam AND right fog light turn on.
    also when the driving lights are on and you turn on the fogs, the left driving light also turns off and tleft fog is really dim but right driving light and fog light work.
    any ideas? cheers
    Jan 2009
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Sounds like an earthing problem.
    Any electrical mods or accessories done?
    Jan 2009
    nop stock as a rock atm mate. yeah you could be right. i remmeber on my skyline there was a bolt behind the headlight that wasent grounded and it made everything play up. would you have any idea where the grounds for the lights are?
    VZ A4 Saloon
    Nov 2010
    If you are going to disconnect the earths. Make sure the battery is first disconnected. Else you may get error messages etc.
    There is a ground just below the ABS module. There is also one just behind the battery and bolted to the inner guard, this one is a white connecter plug with multilpe wires attached. You will need to move the battery to access. Press tang to disconnect.
    Also check relays. Removing and or replacing (swapping with like ones) these may help you to isolate the problem.
    You could also check the wiring connector which plugs directly into the back of headlights.
    And cover your ears in preparation for the alarm to sound (have your keys handy).
    Jan 2009
    cheers bud...ill try tomorrow during the day. freeezing outside at the moment!
    VZ A4 Saloon
    Nov 2010
    Yeah I agree. Poor me was out there in the cold and dark earlier looking for earths.
    Jan 2009
    now u made me feel like i should check now
  1. Accessories turning on by itself after turning car off
    By Danny40 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-04-2011, 11:04 AM
  2. indicator not turning off when turning corner
    By jared_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2009, 11:11 PM
  3. headlights not auto turning off
    By sawtell in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2008, 06:33 PM
