Results 1 to 9 of 9
Thread: Vibration/flapping noise @ speed
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Question Vibration/flapping noise @ speed
    Hey guys.
    I have a 2005 R8 Clubsport.
    Now and then when I drive, I can hear like a vibration/flapping noise coming from the general driver door/ frond guard area. Low down in that area.
    It sounds almost like a thin plastic flapping in the wind. That crossed with when you have a plastic bag in a high wind. Kinda har to descride.
    Doesn't seem to be constant and it randomly comes and goes but it usually occurs when I am traveling between 60kmph and 80kmph.
    I did notice it today alot however and today was a very windy morning.
    My first impression of the noise was that it was in the side skirt potentially, but today when I hear it I would say that i my head it sounded like there was air getting into the door and the clear plastic sheet thing was vibrating.
    Just wondering if anyone else has had a similar noise and what the issue/solution was?
    I thought it might be the indicator in the guard being loose or something, but when I fiddled with it, seemed snug and secure.
    Any ideas?
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Jester
    Check the inner guard plastic liner. If it is missing a couple of scrivets, it could flap aroound at one end. I experienced that in an old Camry recently.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Checked inner plastic guard... seems to be correctly fitted and no wiggle.
    Other ideas?
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    It's a bit hard to picture your car as it isn't standard like mine and I'm not familiar with the HSV details. What modified parts are there in that area apart from the sill panels? The inner door watershield wouldn't make that noise because it's trapped between the door and the doortrim and it's fixed pretty well with that bloody strong adhesive. Does anything rattle when you open and "shake" the door? Is the plastic corner piece that fits behind the exterior mirror sitting flush as it should?
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    What size tyres are fitted?
    Mine are 245 and are very close to the strut. You can actually see where it rubs on the side wall occaisionally. Where the strut is welded to the spring seat.
    The ABS sensor wire can also protrude through the inner guard more than normal. This makes it very close to the tyre again.
    Wheel nuts tight? Are the wheels from a VE?
    Jack the front up. And spin the wheels and see if you find any unusual noise. Check for bearing play while your there.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by Calaber View Post
    Nothing modifed body wise.
    I haven't noticed a rattle when opening and closing the door, but I will conduct thorough testing.
    Will check mirror plastic bits.
    Quote Originally Posted by heyitsEnricoPallazzo View Post
    Wheels are the the same as they fit to the VZ SSZ and Monaro so shouldn't be clearance issues. Running 235's from memory...
    I will check the ABS sensor wire.
    Cheers.
    VZ Wagon
    Jun 2011
    Brisbane North
    You might check the black air dam thingy under the front stone tray as well. If you are missing just one pin it will flap.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Thanks for the input guys, I think I tracked it down to the plastic trim @ the bottom of the windscreen. Yeah, I was surprised too since I thought the noise was coming from alot lower!
    I noticed that a little metal clip was not under the rubber seal like it should be and thus the corner of the trim was a bit loose.
    Went for a drive today in both 80kmph and 100kmph zones without the noise occuring.
    So far, so good.
  1. VZ V6 ute noise and vibration
    By 2005vzute in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-06-2010, 12:53 PM
  2. Where does the flapping noise come from?
    By Ray De Man in forum Car Audio
    Last Post: 04-06-2009, 08:57 PM
  3. Vibration noise ?
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2008, 01:04 PM
  4. vibration noise on take off
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2007, 07:36 AM
  5. vibration at speed
    By RufusŪ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2005, 02:58 PM
