Results 1 to 6 of 6
Thread: Oil waring light
    2005 Wl Statesman
    Nov 2010
    Default Oil waring light
    has anyone had this indication come up on there screen? and what was the cause of the problem for it to happen? and how would i go about fixing it?
    only had the car serviced a few weeks ago and got this warning
    VS Stato l67
    Mar 2009
    Melb
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    2005 Wl Statesman
    Nov 2010
    Quote Originally Posted by monkeys437 View Post
    Where is the oil level?
    the oil should be full, only had it serviced late last month
    Quote Originally Posted by 304runner View Post
    have you washed the engine bay at all after the service?
    no havnt washed it yet
    VS Stato l67
    Mar 2009
    Melb
    I know the oil SHOULD be full, but If I saw an oil pressure warning light on my dash I would pull over to the side of the road and ensure the oil IS full.
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    FARK! You mean to say you haven't even checked the oil ?!! Pretty sure it wouldn't be the first time a 1st year didn't tighten a sump bolt after an oil change... That light you see is what I refer to as the "Too Late Light"
    Get outside and check the oil FFS!
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Replacing light bulb behind demister / interioir light / dimmer switches
    By seabs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2011, 09:57 AM
  3. Light Tempest Light Metallic Silver Paint Code
    By ruredi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-03-2011, 09:32 PM
  4. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  5. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
