Results 1 to 12 of 12
Thread: P0152 - o2 Signal High Bank 2, Sensor 1
    VL Calais Manual, VZ SV6 Manual
    May 2011
    Default P0152 - o2 Signal High Bank 2, Sensor 1
    hey guys i have a vz sv6 and it started to idle a little rough and become a bit slugish.. i took it to a friends work shop and used the scan tool and come up with this code -
    P0152 - o2 Signal High Bank 2, Sensor 1.. i cleared the code and the car idle'd even rougher but had alot more power / responce... after a little while it became sluggish again.... i went back and plugged the scan tool back in... and sure enough the code was back... Can anyone shed some light on which sensor is highbank 2, sensor 1??? and should i just replace that sensor... or does this code mean something different as it says o2 Signal????
    any light on the situation would be great.. thanks
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    sounds like an o2 sensor on the exhaust. check the o2 sensors to see if there are any broken wires of any description. but thats what i would understand from the code description. but i may be wrong. btw, ur mate should know what would throw this code??? he should have told u
    Spoken by a true member of The Committee
    May 2011
    yer for some reason he didnt know lol... just said probably the 02 sensor... he didnt even know what sensor was High Bank 2, Sensor 1 lol
    May 2011
    also read this on a different site - P0152 O2 sensor circuit high voltage (Bank 2 sensor 1)... anyone shed any light on this lol
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Should be the LH side pre-cat oxygen sensor. Probably lazy.
    Should do a O2 onboard test via scantool to be sure.
    What year is it?
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    I read the code as o2 Signal High, Bank 2, Sensor 1. High signal, not high bank
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    May 2011
    it is a 2005 model... pretty sure its march 05...
    Quote Originally Posted by heyitsEnricoPallazzo View Post
    What year is it?
    VZ A4 Saloon
    Nov 2010
    Then it should have only 2 o2 sensors. As apposed to 4 for '06 models. Makes it easier.
    Phyco's Avatar
    Phyco is offline Alloytec and Proud
    06 VZ Acclaim Sedan
    Mar 2009
    WA
    Didn't the 190kw engines always have 4?
    -My VZ Acclaim- feat. ASR Audio Sound/Lighting and Various Other Mods
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by Phyco View Post
    Sowing the seeds of doubt in my mind.
    Euro III only went to post cat sensors?
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    My 2004 Calais 190Kw has got four O2 sensors. 2 x front & 2 x rear. I just replaced the front ones on mine & it sorted out any issues (though fuel economy has never registered quite the same with the after market sensors).
    WL CAPRICE
    Mar 2011
    Quote Originally Posted by Trent L View Post
    Hey just about to do mine in my alloytec caprice.
    Was wondering how much they cost you each And did u do them ur self?
    If so was it hard?
    Dave.
  1. Can a faulty crank angle sensor cause one bank to run rich?
    By Nick JD in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2010, 03:40 PM
  2. 48 - Cam angle sensor (no signal)
    By feezals in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2010, 02:01 PM
  3. Code 13 - Oxygen Sensor (O2) - No Signal - VS V8
    By Dinwoodie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2010, 06:03 PM
  4. Cam angle sensor (no signal)
    By Chris F in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-07-2009, 12:35 AM
  5. 63 LH Oxygen Sensor (O2) - No Signal - again
    By DzRBenson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-05-2008, 11:10 PM
