Results 1 to 25 of 25
Thread: Just Lowered, Need Shocks. Halp!
    VZ Exec 05
    Jun 2011
    Emerald, Victoria
    Default Just Lowered, Need Shocks. Halp!
    So up until 2 weeks ago I had a bog stock VZ Exec Sedan 05. Just lowered it with Super Low King Springs, in both front and rear. Now ride quality isn't as great.
    Can anyone recommend some new shocks & struts for front and rear that will improve it, also will a camber kit be required with super-lows.
    Also, currently have stock rims/wheels on it at the moment, I will be getting 18's in the next month or so. Will that effect the height at all (sorry, semi-noob at this)
    If anyone has a picture or two of a VZ sedan with 18's and super-lows all round, it would be greatly appreciated.
    vr commodore bt1
    Jun 2011
    Basically when you install super lows your ride goes to junk. When I fit super lows to commodores I always chop the front bump stops in half to give you more travel. With shock absorbers I would recommend short stroke koni sports. The fronts are externally adjustable and they will give you a better more controlled ride.
    VZ Exec 05
    Jun 2011
    Emerald, Victoria
    Will fitting new shocks and cutting the bump stops improve ride quality? I am thinking of taking it back to where they were fitted and getting them swapped out for just Lows. I originally went in for just Lows.
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Munroe also have sport gt lowered shocks. Wont need a camber kit. and your rim size wont effect your Tyre size, unless you get the Tyre size wrong.
    VZ Commodore Sedan Monroe GT Sport Lowered Shocks - Online Performance Autos
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    vr commodore bt1
    Jun 2011
    When you change to Lower springs you change your spring rates, this makes your STD shocks to soft giving you a crappy ride, the upped damping rate of new shockers softens the ride and adsorbs the bump better. It won't make it ride like it's on a cloud but it makes it better, your car should have rear toe adjustment. Camber wears your tyres over 30, 000k toe screws them over 1000k. Your commodore should have factory toe adjustment. That's all you need,
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Did you get an alignment after the springs? If so what was the rear camber figure?
    BTW King's recommend shorter shocks and camber kits with SL's.
    Monroe's if you don't have the coin.
    You should also be looking at fat sway bars. Or your pissing in the wind.
    VZ Exec 05
    Jun 2011
    Emerald, Victoria
    Ok so I've decided to stick with the super lows. Been looking at Online Performance Parts, and have come up with this list.
    Commodore VT VX VY VZ Nolathane Evolution Camber Kit
    Commodore VT VX VY VZ Nolathane Evolution IRS Toe Kit
    Commodore VX2 VY VVZ Nolathane Sway Bar Link Conversion
    VZ Commodore Sedan FRONT & REAR Adj Whiteline Sway Bar
    VT VX VY VZ Commodore F Suspension Bush Kit - Nolathane
    VY 2 & VZ Commodore Front Whiteline Alloy Strut Brace
    When I got the springs installed, mechanic said I need new strut top mounts - Strut Top Mount & Bearing Kit Holden Commodore VX VY VZ
    So that's the stuff on my shopping list. Not sure what the Toe kit is, but it mentions using it with the Camber kit. The shocks, sway bars and camber/toe kits are the most important, but I thought while they're doing all that, they can change the bushes as well.
    Not entirely sure what the Sway bar link conversion kit is, or the alloy strut brace, but they aren't expensive so thought I'd get that to. Any direction would be awesome.
    VZ A4 Saloon
    Nov 2010
    Nolathane Evo camber kit is rubbish. Have it.
    You dont need the link kit. Not suitable.
    Nolathane toe kit does camber as well. Probably crap.
    Strut brace is for show. Some might disagree.
    You will experience some additional harshness by installing poly bushes.
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    KYB shocks, superpro camber kit, whiteline front and rear swaybar. done
    If it isnt tuckin, it must be suckin
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    Quote Originally Posted by heyitsEnricoPallazzo View Post
    depends, some people claim better handling through corners but only at insane speeds, on a street car they are pretty much for show
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    for the record Monroe GT Gas are absolute rubbish. I had everyone whose never used them tell me how wonderful they are, especially with the king spring. The one bloke who has had them told me otherwise, but I went with the crowd and bought a set.
    I'm now currently saving to replace the damn things, the reason I brought the car was because of its handling into corners, as soon as I put the GT's in that literally went out the window and its become a handful.
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by DM 55 WA View Post
    Tru dat!
    Quote Originally Posted by Torquative View Post
    What other suspension mods do you have?
    Have to agree the Gt's (sport) are pretty ordinary. The ride is very fidgety at low speed. I have just replaced a front strut with less than 25k klms.
    But for some reason I am still happy. Just used to them I guess. Or maybe all the money I spent on suspension mods makes them look reasonable.
    VZ Exec 05
    Jun 2011
    Emerald, Victoria
    Ok, so looking at the whiteline swaybars, there is a few options.
    VZ Commodore Sedan FRONT & REAR Adj Whiteline Sway Bar (which is the Heavy duty adjustable front and rear)
    Go adjustable or not? And I'm in Vic, so anyone know a joint that stocks the KYB excel-g's and the superpro camber kits? Guy on the forums, gslrallysport can ship kyb's and whiteline camber kits, just waiting a reply for price.
    Also problem question..if i slam the brakes on, there is a knocking noise/sensation almost underneath/in front of the accelerator pedal. sounds horrible. looking underneath or while its hoisted, cant see anything. only does it on the front right wheel.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Koni Yellwo Sports adjustables and adjustable Whiteline bars FTW.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  15. #15
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    That could be that bearing that needs replacing.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
  16. #16
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    KYB AGX's are supposed to be the shit, id be looking for some of them.
    Then whiteline front and rear swaybars, and a whiteline camber kit would be good too.
    done,
  17. #17
    95 VR V6 Turbo Ute
    Oct 2009
    Sydney, North Shore
    Strut braces do actually work, you'd be surprised how much your chassis rolls in corners. Putting one in my commodore soon, got one in mx5 and it is amazing.
  18. #18
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by p1xel8ted View Post
    Noise could be the strut top bearing. Get Poly and new bearing.
    Adjustable sway bars. You probably will not notice the differenece on the street.
    Make sure you replace your torsion bar (z-bar) bushes with poly. If you have not already.
  19. #19
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    done,
    You say you are fitting 18"s so keep your tyres to 235 as some 245's will rub on the strut spring seat.
    Mine was with 245/35x19's as shown which is why I went to Koni's.
  20. #20
    VZ Exec 05
    Jun 2011
    Emerald, Victoria
    With the KYB excel-g, they only make them for the VY, I can use the VY ones but I'd need new links or something. What's the name of said links?
  21. #21
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    KYB make shortened front shocks now to suit VZ fronts, no need for links etc.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  22. #22
    VZ Exec 05
    Jun 2011
    Emerald, Victoria
    OK another question :P
    Front tyre wear is screwed, before I got it lowered, I reckon half of my tyres on the inside were almost bald, the outside half was OK. Just my front tyres this is. Now, I had about 5 wheel alignments over a 2 month period, nothing. Would take a week (if I'm lucky) and it would revert back to its pre-wheel alignment state.
    Now taking a long left corner, and your arm can start to ache, taking a long right corner and its smooth as. Power steering fluid is all good. Now I'm planning on getting Whiteline adj. sway bars fitted (on that note do I need to purchase sway bar links to?)
    On eBay I have found tonnes of rear camber kits, do they make front camber kits for the VZ?. What's the difference between these two, and does it justify the 70 buck difference.
    SuperPro - Commodore rear Camber Kit Super Pro VP VS VT VX VY VZ
    Whiteline - Holden Commodore Camber Toe Correction VT,VX,VY,VZ, HSV
    Thanks guys.
  23. #23
    VZ A4 Saloon
    Nov 2010
    What exactly have you done to your suspension so far?
    No links needed.
    You only need a two point kit. However buying a 4 point kit will be cheap insurance as the inner voided rubber bushes can fail after fitting a 2 point kit.
  24. #24
    VZ Exec 05
    Jun 2011
    Emerald, Victoria
    Ok,
    - Lowered with King Spring Super Lows.
    - 18's fitted.
    When the KYB struts & shocks arrive from Greg, I'll be fitting those along with new strut top mounts and strut brace.
  25. #25
    VZ A4 Saloon
    Nov 2010
    Camber is adjustable on the front from standard.
    The front tyre wear issues may be your aligner. Sounds like the have stuffed the toe settings. If your suspension was or is at fault, the aligner should have picked this.
  1. monroe lowered shocks
    By dakman in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-03-2010, 09:31 PM
  2. lowered VS IRS springs/shocks on a VP?
    By gsxrdan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2009, 12:01 AM
  3. Lowered Shocks - Help!
    By sweefu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2009, 04:54 PM
  4. Lowered Shocks?? Need Help!
    Last Post: 18-03-2009, 12:54 PM
  5. how much for 4 shocks and lowered springs
    By Sandman240588 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2006, 10:47 AM
