Results 1 to 3 of 3
Thread: squeeking sound in vz exec
    sleek_vp is offline sleek_vp
    VP Commodore V6
    Mar 2007
    brisbane
    Default squeeking sound in vz exec
    again my car has a squeeky/ creaky noise under the rear, i just replaced the control arm bushes so im a bit baffled, iv read on other forums that it can be a 'sticky' handbrake which i will fix but im after anyone with the same experience or knowledgae on how to sort this problem, the noise realy becomes apparent when the suspension needs to articulate or over speed bumps or any bumps real slow or when the cars stationary and you lift the car up and down from the towball, any advice is much appreciated thanks
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Were the bushes you replaced polyurethane? These can get noisy if they lack grease.
    Monaro v2
    Jan 2010
    Gold Coast
    Have you checked the bushes on the rear shocks. Or even the rubbers covering the bump stops and between the springs. if the sound is coming from the car moving up and down a i would concentrate on your suspension.
    Every time you go for a drive just lube up a different joint in your suspension. That way when you take it for a drive and the noise stops you know exactly where it came from.
  1. squeeking drive belt..?
    By PUSHIN in forum General
    Last Post: 15-01-2011, 12:53 AM
  2. squeeking shocks
    By axemurderer101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2008, 10:01 PM
  3. Brake Pad Squeeking
    By r_i_d_a_h in forum General
    Last Post: 10-09-2007, 05:37 PM
  4. Need help with choosing best sound system for VS2 Exec.
    By DTDCommodore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2005, 10:02 AM
  5. new brakes still squeeking
    By riss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2005, 08:47 PM
