Hey guys my left rear window no longer works. About a week ago it started playing up only working when it wanted to. Now it wont move at all.
Could i be as simple as a fuse somewhere or do i need a new motor?
Try the switch on the door? My back window doesn't work unless I fiddle around with the switch...
Could be dust only under the switch. Use a vacuum cleaner with an extension for the hard-to-get places.
The only Exec in Saudi that's now properly badged!
you could swap the rear window switches to see if that solves the problem, or you could try holding the switch on and give the door a few good whacks with your fist to see if that gets it working.
Sounds like poor connections. Take the switches out, give them a clean and make sure the terminals are connected firmly. One of them may have come loose.
Have a look at the wiring in the loom between the rear door and the pillar to make sure the wires are intact .common problem with the VT VX .
