Hey guys i have the vz ss headlights with the low beam projector bulb and as you know the right light beam has an arc that goes to the ride side of the road and the left light beam has an arc the goes to the left side but the left hand side beam arc goes to the right just wondering if anyone has had this problem and how they fixed it?
thanks
OZTEEL
Im not sure I fully understand your problem. But......if I was you, I would take the globe out and reinstall and make sure its sitting properly. Check with the other side just to be certain. Unsure if this will fix your dilemma.
Otherwise, try some adjustment with a phillips head screwdriver. There are arrows above the light when you pop the bonnet. You can adjust the light "left and right" and "up and down" directions.
Goodluck![]()
hey mate yer checked to make sure there tight and it all good but cant find the adjustment screw to make them go left or right? thanks
OZTEEL
Check out the pics in the thread link below. Should look very similar to this;
Headlight Adjustment.
yer cheers mate ill have a look tommorrow during the day. would this be the same for my lughts as there vz ss lights? thanks heaps for the reply and the pic.
OZTEEL
Same mate. I have a VZ and they are very much similar to the pics in the link. Look carefully and you won't have any trouble finding. Goodluck![]()
cheers mate found it. and apparently the arcs are both ment to be going towards the right so i dont shine on coming traffic but mine where just too close together. thanks heaps for your help.
OZTEEL
No worries. Anytime![]()
