Results 1 to 14 of 14
Thread: Driveshaft problems anyone?
    tHe_sTiG's Avatar
    tHe_sTiG is offline <--- Want a ride?
    VZ Executive
    Jan 2010
    Saudi Arabia
    Default Driveshaft problems anyone?
    I got my VZ back from service a couple of days ago. Straight out of the service center, the whole car was rumbling and vibrating at speeds of 60 - 80 kph. Noticed the tyres had been rotated, rotated them back again, reduced tyre pressure from the 40 they had set to 35. Less drama this time, but still noticable vibration.
    Thought this must have something to do with the driveshaft (probably misalignment), since they had replaced a bearing during the service. Took the car back and complained about the problem. After a day they called and said that the cross-joint of the driveshaft was damaged, and I would need a new driveshaft.
    What's going on here?? How could this problem have suddenly showed up like this?? Before servicing the car was driving as smooth as silk at any speed. Now that they've replaced this bearing, this vibration shows up??
    Another thing that concerns me is after picking up the car after road-test, I found the volume had been adjusted to nearly full blast on my CD player... forgive me for thinking this but I believe my car was abused during this "road-test"...
    The only Exec in Saudi that's now properly badged!
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Was this a Holden Service Centre? I took my SS to Holden once. Never again.
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    What bearing was replaced?
    Also I would not give that particular service centre my business anymore. Obviously incompetent.
    tHe_sTiG's Avatar
    VZ Executive
    Jan 2010
    Saudi Arabia
    Quote Originally Posted by heyitsEnricoPallazzo View Post
    Not sure, except that it was a bearing on the driveshaft. The guys said the bearing was broken and needed a replacement.
    Quote Originally Posted by aaronevolution View Post
    It's a GM service center in the Middle East, same thing I suppose. If you don't service it at Holden, where else can you get it serviced? Or do you guys service your cars by yourselves?
    VZ A4 Saloon
    Nov 2010
    Probably the centre point bearing.
    Bet they have damaged something or not installed the shaft correctly. Get a second opinion.
    I service my own vehicle. Exactly because of the problem you have - poor service and bull.
    90 mazda 323
    Oct 2010
    perth nor and lovin it
    he's right on about that one, holden service centre are s**t
    90 mazda 323
    Oct 2010
    plus i service my own car too and yeah you better off starting to learn how to service your own car at least you no that you did it right and you will save money too
    06 vz sv6
    May 2011
    south east sydney
    They probably didnt install it properly so it wasn't balanced. This would normally cause your centre bearing to fail
    VS Stato l67
    Mar 2009
    Melb
    The middle slip joint in the newer model driveshafts is prone to wearing out very quickly and holden dont stock/supply replacement parts, only complete driveshafts assemblies so thats all they can sell
    tHe_sTiG's Avatar
    VZ Executive
    Jan 2010
    Saudi Arabia
    Hi fellas, there's a good chance it might be a handbrake shoe causing all this vibration. I was driving along today and heard a slight squecking sound. Dad was with me and pointed out that it definetely must be the one of the brake shoes of the handbrake rubbing against the inner wall of the drum.
    Before service, the handbrake would only lock one wheel. Also the brake shoes had been changed quite a long time before this service. After fixing the problem and getting both wheels to lock, this shows up. Probably because of uneven wear of the brake shoes, since one of them was never actually used due the locking fault. Will be taking it to GM tomorrow... hope that ends the problem.
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    I service my car myself, but most likely it was abused on the test drive. I work in a truck workshop and its our job to kane the living hell out of anything we test drive. As far as a mechanic is concerned, the more problems he can find, the better he does.
    So I strongly reccomend looking for problems yourself or specifically telling the service centre not to drive the car on the road, only drive it in and out of the service bays.
    tHe_sTiG's Avatar
    VZ Executive
    Jan 2010
    Saudi Arabia
    Got the brake shoe adjusted, no test drive this time. Seems to have solved the problem. Hopefully wont have to worry about anything for at least another year. By then I will have found someplace else to do the servicing for me anymore.
    I forgot to mention that the major service I had a week ago cost me $900, more than half of that was labour cost alone. Nothing out of the ordinary was done according to the invoice I got, just the brake pads were expensive as hell. I'm sure I'd save a lot if I take the car somewhere else for servicing.
    VZ A4 Saloon
    Nov 2010
    So that was 3500 Riyal?
    You should adjust the HB shoe yourself. It's very easy.
    tHe_sTiG's Avatar
    VZ Executive
    Jan 2010
    Saudi Arabia
    No, that was for the entire service, still alot. After that, everything they messed up was fixed for free. I'm not a mechanic, neither is dad. My old man believes that the GM service center do an excellent job, gets really peeved off when I tell him they're doing more harm than good. After these few incidents, and the crazy price, he's considering servicing it elsewhere anymore.
  1. Driveshaft
    By M01ST in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-04-2010, 08:10 AM
  2. One piece driveshaft??
    By Jordo2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2010, 10:54 AM
  3. vs ute driveshaft?
    By mitchvsute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2009, 09:18 PM
  4. Vr Ss Driveshaft Help!
    By mark1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 10:06 PM
Tags for this Thread
