Is this the look your after?
From experience if you only lower the front your handling will drop by alot.
Specially when you tab the brakes.
Another option, If u wana lower the front You may be better of lowering the back a little aswell but you will have to get super heavy duty springs in the back to handle the load in the tray.
Dave.
Check out My WL CAPRICE
http://forums.justcommodores.com.au/...price-l-k.html
why not get SL kingsprings that are HD - not overly low and still tough
What are they rated to though? Darwin is ridiculous when it comes to utes, I cant even put rims on my car.
I think the superlows will drop the back about 30 to 40mm.
Not really sure for utes thou.
Give kings spring a call and they will tell u exactly what ur after.
Yeah ill give them a call on Monday. Unless they are rated to carry 1.5tonne or above im screwed though. Previous owner got it certified that high so it has to remain there according to the Darwin MVR.
