Results 1 to 6 of 6
Thread: VZ Climate Control
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Default VZ Climate Control
    Hey,
    Quick question in regards to the climate control in the VZ, specifically a Clubsport.
    When I set the temp using the buttons on my side, say I put it @ 20degree's, the only options the passenger has is either "C", "20" or "H".
    Is this correct?
    Also, when they the passenger sets it to "H", I swear it blows hotter on my side too?
    Thoughts? Experiences? Etc?
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    My mates vz clubby seemed to blow different temps when set at the same temperature. I think that not long after I noticed this happening, he then was welcomed with a small "x" in the climate display which we were told was a problem with the unit and this could be the cause of your issues too. Unsure exactly what the "x" meant.
    With regards to the only available temps being "C", "20" and "H", well I have no idea on this. But again, you may have an error somewhere and the "x" on the display is yet to show its ugly head.
    Maybe someone can shed light on whether a tech 2 will show any faults if a test is or can be run?
    Do you have a temperature probe that you can put into the vents and just check the temperature difference, and then maybe get a mates commodore with climate and compare?
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    Don't know about the Clubby - but in the Calais both driver & passenger sides go up/down in increments of 1 degree.
    Lowest is C then goes up 17, 18, etc
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Hmmm... I may have just found the issue.
    As it turns out, the VZ CLubsports only have single zone climate control.
    This would explain alot. Learning something new about my car every day.
    Holden VZ
    May 2011
    Yea I'm pretty sure the VZ SS an Clubby are not duel it's just single, the left hand side if u push the C it's goes straight to the coldest if you were to push the H it goes straight to the hottest kind of a shortcut to the aircon where as the drivers side is single degrees at a time, did that make sense? But yea that's my understanding
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Yeah, I think you're on the ball mate.
    Did some further reading and checked the "HSV Classics" section.
    Single zone and as you say, the LHS buttons are like a hottest, coldest shortcut.
  1. VR V6 93 Acclaim heater control / climate control switch
    By tom slick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2011, 02:26 AM
  2. [VIC] vr vs climate control heater box and climate control panel.
    By python_hunter1 in forum Parts And Other Items For Sale
    Last Post: 25-03-2011, 08:50 PM
  3. climate control,how does it work need to know for climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2010, 12:49 PM
  4. [VR-VS] How to change Heater Control globes (NON climate control)
    By Fonzie in forum Holden Commodore How-To's
    Last Post: 03-08-2009, 11:28 PM
  5. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
