Results 1 to 7 of 7
Thread: VZ calais dash cluster swap into VZ executive
    jd hot stuff's Avatar
    jd hot stuff is offline The power of 253
    VB SL 253
    Jul 2006
    Melbourne VIC
    Default VZ calais dash cluster swap into VZ executive
    Hi guy's. Just wondering if any one would know what has to be done to swap a VZ calais dash cluster, into a VZ executive.
    Cheers from Justin
    When you fall off the pace with the car you brought to the race, I'll be the one who's flying by you kickin' sh#t in your face
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Think the plug is the exact same, all you need to do is go into holden and get it programmed.
    VB SL 253
    Jul 2006
    Melbourne VIC
    Ok thanks mate cheers for that
    Holden VZ
    May 2011
    Quote Originally Posted by jd hot stuff View Post
    Cheers from Justin
    Hey mate look up threads on these it's much or difficult then a plug an tune you have to change sensors heater boxes an a load of crap inside an outside thermometers. I'm not sure myself but there is loads of threads on it so look them up
    one_and_only2004's Avatar
    one_and_only2004 is online now Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Quote Originally Posted by CORNYY View Post
    He's changing the speedo, not installing climate control. As said, it'll be a tech2 programming affair at holden.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Holden VZ
    May 2011
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    Quote Originally Posted by one_and_only2004 View Post
    Correct.. I know this cos i have done it
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
  1. vr dash cluster swap over
    By 88pete in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2010, 08:31 AM
  2. VZ Dash cluster swap
    By Corbs1234 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-12-2009, 09:44 PM
  3. [VIC] WTB/swap vn bt1 dash cluster
    By NOT.BT1 in forum Swap / Wanted to Buy / Trade
    Last Post: 03-11-2009, 09:46 AM
  4. Berlina dash cluster into Executive?
    By <atomicL93> in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-07-2009, 02:12 AM
  5. dash cluster swap over
    By Ross D. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 08:20 PM
