Hi All, Has anyone come across this problem before, the " Service Vehicle Soon" warning signal keeps appearing the manual says that it could be a transmission problem or a non emissions related fault in the electronic eng manag sys ??? is there anyone else who has had this problem and what was the outcome ?? I will be taking it to a holden dealer tomorrow to find out the problem but im very curious to know what the issue is
PS it isnt the Service Reminder signal ... this is a FAULT
if it has got the alloytec v6 then most likely its the oil pressure switch. very easy to replace
ian
Yea it will more that likely be the oil pressue sensor. Did it on mine not long ago. The part should be around 70-90 dollars. You dont have to go to holden to get it done though your regular mechanic can do it aswell. Holden will probly charge you just to plug the scan tool in.
Thanks Guys for the quick response i'll look into .... Always handy to have some idea of what the problem could be b4 going and seeing Holden Dealer??? Thanks again
definately an oil pressure sensor. mine pops up, i just turn off the car, turn it back on and its gone lol
