Results 1 to 25 of 25
Thread: Experience with Subaru upper engine cleaner?
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    Default Experience with Subaru upper engine cleaner?
    Hey guys,
    Has anyone ever used a can if Subaru upper engine in their alloytec?
    I know that some cars love it, and some hate it .
    For those who don't know about it, it's great... Toxic as all hell but will clean anything. It's sold and branded by Subaru and is designed to clean the intake manifold and combustion chamber..
    Any experiences would be good.
    scvs6's Avatar
    scvs6 is online now Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    You don't have to use the genuine subaru upper engine cleaner. At work we use Wynns Fuel Injector Cleaner, it says to add to tank but we run it through every subaru that we service. I have also run it through my VS ecotec a few times and have had no trouble at all.
    I just disconnect a vacuum hose off the maf sensor (on the VS) and run it through there. Subaru's theres a couple of vacuum hoses on the top of the inlet manifold.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    ive used tb cleaner (nulon) in my car, it made it hard to start, and let out a little bit of smoke and thats about it lol, cant say whether it was worth the money or not, but i certainly did clean out the pvc pipelines and all the other pipelines that connect to the manifold, didnt notice much difference
    Spoken by a true member of The Committee
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    the spray stuff is brilliant. iv used it in many cars and noticed big improvements all round. best used with the engine running so it can suck it right down.
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by Maxxiz View Post
    Hey guys,
    It's designed for the peculiarities of the boxer engine. But it probably wouldn't hurt.
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    VZ SENATOR
    Mar 2009
    May 2009
    Gold Coast
    problem is with the alloytec, if you disconnect a vacum line, it stalls, well thats the prob i had when i went to spray it in there, unless theres a specific vac line to spray into when the car is running?
    VZ SENATOR
    Mar 2009
    VX SS
    Jul 2005
    East of Melbourne
    My daughter has a Subaru Imprezza and the Subaru dealer used a bottle of stuff that is added to the fuel not a spray of any sort, they also gave her another bottle and said to add it to the fuel at the midway point between services, from memory reading the container it said for controlling carbon deposits in the intake and around the valves and cleaning the fuel system, it was more than just injector cleaner but used as a fuel additive not a spray.
    I will have a read of the container tomorrow as I have it in the garage from the last Subaru service.
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    Drewie .... think your getting your additives mixed up.
    There is a Subaru service part no. SA459 Upper Engine Cleaner which is an aerosol used every service. It's sprayed directly into the inlet through the vacuum hose connection (can also spray some into the air intake to remove gum deposits).
    Half a can is sprayed it then wait 10 minutes. Then the vehicle is started & whilst idling (juggling the throttle cables) the remainder of the can is sprayed into the inlet & the engine is turned off. Wait another 10 minutes, then restart the engine & rev the crap out of it to 4000+ revs till the smoke from the exhaust clears. Reattach the vacuum hose.
    It looks lie a jumbo jet on takeoff whilst revving it out to decoke the heads - but take it for a drive afterward & it's like an asthmatic having just had a suck on their puffer spray.
    Separately, there is the fuel additive SA718 which is used at service & half way between services to help keep the injectors clean.
    The SA459 is specifically to decoke the heads in a boxer engine. I'm not to sure how you'd get it into a VZ or what benefit it would give for your $20 a can.
    Just make sure they use it when servicing your daughters Soobie though. It does make a difference to them.
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    It worked well on my old vs v6 ute, cleaned it out good, however dont do it in your garage LOL almost killed myself from the fumes holy shite there strong lol
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Does the job. Not sure I would use it on VZ engine... they shouldn't have that much buildup in them to start with.
    Just run premium through it every month or so and that should be enough.
    VX SS
    Jul 2005
    East of Melbourne
    Quote Originally Posted by Trent L View Post
    Thanks for the above info 'Trent L' just checked the container in the garage it is SA718, she has only had the Subbie for a few months, she had it dealer serviced at Lilydale (Eastern Subaru), do the dealers use the spray stuff on any particular service? Her Subbie has a full Subaru dealer service history from new. Thanks again for the info.
  15. #15
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    yeh I used it on the Acclaim about 2 years ago, I'll try and find the video clip of it
    Dunno if it made a difference as we also tuned it that day, but it definately created a lot of black smoke for about 3 or 4 seconds after starting it up so it did something
  16. #16
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
  17. #17
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    Yea I've heard great things about this stuff, I'll be doing it during my next service!
    Would be interesting to so some before and after photos of (for example) an ecotecs plenum to see if it cleans up the dirty bastard much...
  18. #18
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    Ford (MotorCraft) have an aerosol that is exactly the same stuff.
    They are made by Bar's Leaks.
  19. #19
    2005 VZ SV6
    Jun 2009
    Thanks for the input guys, it's not the price/availability I'm worried about, I've got the stuff coming out the rear end. I'm just curious, i know it works great in subaru's, I use it every day, just wondering bout the alloytec in particular, as I've heard in some other cars it can make things worse, set off error codes etc...
  20. #20
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    just make sure to give it a rev while spraying it in so it doesnt stall. just to make sure it gets all the way thru.
    edit: first time i used it on the wifes car i just sprayed it in the TB with the engine off, it nearly comression locked. so i wouldnt recommend using it with the engine off.
  21. #21
    2005 VZ SV6
    Jun 2009
    Not sure it could compression lock? When I use it it subies, as directed, spray half into intake vac line let it sit, then crank till starts then rev and empty rest of can.. Never any probs
  22. #22
    VK Executive
    Nov 2008
    I have used it a few times, Didnt really seem to do much. Would like to try seafoam though.
  23. #23
    Torquative's Avatar
    Jun 2005
  24. #24
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Just one thing to note... this stuff is designed to work in boxster engines specifically.
    Using it on other configuration engines CAN increase the chances of it doing damage of some sort.
    When I did it on the bimmer it was spray it in and make the car stall. This stuff needs to sit in the cylinders in order to work. This is risky area number one since you can hydrolock if you pour it in there like a retards.
    Then, you start up and rev it out. Risky area number 2 because if there is enough shit coming out if can clog cats up abit plus foul O2 sensors.
    You also want to make sure you get it ALL out as from what I read it can degrade rubber seals.
    Good luck.
  25. #25
    VE SV6 ute
    Apr 2009
    vic
    can you use that foam stuff to clean ur upper manifold?
  1. Problem with a mates Engine ( Subaru 1.6L )
    By VTIICalais in forum General
    Last Post: 10-02-2011, 10:13 PM
  2. Upper Engine Cleaning on old Engine (Unopened)
    By Jesterarts in forum The Pub
    Last Post: 17-02-2010, 09:02 PM
  3. subaru engine cleaner for vn ok & how to use ?
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2010, 10:31 PM
  4. Subaru Upper Engine Cleaner...
    By HoldrodeoLT in forum General
    Last Post: 02-02-2010, 09:54 AM
  5. GM Top Engine Cleaner
    By AlpineRaven in forum General
    Last Post: 31-08-2009, 03:59 PM
