Results 1 to 7 of 7
Thread: help please! 02 sensor question
    calais turbo, ve ssv ute
    Jun 2011
    bankstown
    Default help please! 02 sensor question
    hey guys just wondering what in gods name does this mean?
    P2234 - Generic
    Type Powertrain - Fuel and Air Metering and Auxiliary Emission Controls - ISO/SAE Controlled
    Description
    O2 Sensor Signal Circuit Shorted to Heater Circuit
    Location Bank 2 Sensor 1
    Notes
    P2231-P2236, This diagnostic is for the sensors (both wide band and switching) that have a PWM controlled heater. If the heater shorts to the signal circuit, the control module can determine this since the signal circuit will be shorted high at the same frequency that the heaters are operating at.
    Any help would be great, thank you!
    WL
    Mar 2011
    adelaide
    sorry to hijack Hicomp but I have the error P2231 - O2 B1S1
    so if anyone can tell me which O2 sensor that is... (passenger side front?)
    thanks
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by Rzpect View Post
    thanks
    Cylinder 1 is on RHS. So bank 1 should be RHS.
    Should be front sensor.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by Hicomp View Post
    P2234 - Generic
    Description
    Notes
    Sounds like the same issue that the VS had. Replacing the sensor won't fix it, you will have to rewire the earth for the sensor back to the PCM, or cut the heater wire. I don't know which one it is on the VZ.
    Visit my Facebook page
    Jun 2011
    bankstown
    yeah u guys took too long too respond hahaha, replaced all four sensors and no more check engine trans light!! happy days.
    i had that error code and 2 other sensors sending out some crap codes so thought might aswell replace all of them.
    but thanks guys!
    WL CAPRICE
    Mar 2011
    but thanks guys!
    Good to hear its all good now.
    I just changed my front ones but might change the after cat ones.
    Just wondering how much did they cost you?
    Cheers.
    Jun 2011
    bankstown
    Holden quoted me on 159
    Each but only payed 80$ each so pritty good price considering they are genuine, they were purchased from
    Muirs Holden parramatta rd.
  1. Another oxygen sensor question
    By baroofy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2011, 08:01 AM
  2. knock sensor question
    By vnskidder in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-07-2010, 07:10 PM
  3. oxygen sensor question
    By zskinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2010, 06:18 PM
  4. Map sensor question??
    By UN4TOLDVRSS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2008, 07:59 PM
  5. speed sensor question
    By demonflesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2005, 08:10 PM
