Results 1 to 5 of 5
Thread: Extractors and Highbeams blowing fuse
    VX EXECUTIVE SERIES 2
    Jan 2009
    Default Extractors and Highbeams blowing fuse
    Just got two questions here.
    Are there any other models we can pull extractors or a cat back from? vs vp? etc?
    Im basically looking at a full system but opening up the standards cats with a 2.25 single lukey system. I was looking at some pacy's and wondering if we can take them off any others.
    Also strangest things happening. when im driving along with my low beams/driving lights on and i try and turn the high beam it blows the high beam fuse straight away! and also when the fuse is blown and you try and turn on the highbeams the right drops out and the left comes on. any ideas?
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yes, this is in the wrong forum, but as far as exhaust goes, VT-VY exhausts are interchangeable as long as you are going from sedan to sedan and V6-V6 etc.
    With the lights, it sounds like the dipper switch on the indicator stalk has shit itself, common problem with VT-VX's.
    Visit my Facebook page
    Jan 2009
    DAM! sorry! i havent updated my profile! i have vz ute sv6. sold the vx a while ago. better update it. The high beam ended up to be the positive to the bulb shorting out on the body but with exhausts can we swap from any other models?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I wouldn't bother with the VZ, the V8 models VT-VY will bot straight on to the V6 VZ but it doesn't do much at all. Ute only, sedans won't fit.
  1. My fuse for the dash lights is blowing (number 1 - 15amp fuse)
    By aussie7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 06:10 PM
  2. fuse blowing
    By tex66 in forum Electrical Wiring / Questions
    Last Post: 12-01-2010, 04:26 PM
  3. Blowing fuse..
    By Lloydy1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2009, 09:16 AM
  4. fuse keeps blowing
    By to_easy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2009, 08:42 PM
  5. My car keeps blowing fuse
    By bellasmummy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2008, 06:24 PM
