Hi guys, i have a 2004 VZ Sv6 Commodore with superlow springs and 19" SSV rims. I currently have them fitted with the standard VE tyres which are 245/40/19 and they scrub in the rear over any little bump, and going around corners, just wondering what size tire i will need to get to have no rubbing. 235/35/19 be ok??
VT-VZ'scan use either 235 or 245/"35" x 19 tyres, I have 245/35x19 fitted to 8.5" (holden usually 8") on my senator.
After a little trim off the top inside edge of the rear bumper where it meets the the body any rubbing over bumps had gone, this is the spot where they usually rub as the susp goes up and down.
40 series 19's a way too tall without a lot of trimming in that area and still may rub/scrape.
Also if you lower the car you will start having rubbing on the fronts too.
No matter what tyres you use getting your guards rolled is definitely a step in the right direction.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
yes i will be getting the guards rolled and i have noticed the bit that does most of the rubbing where the bumper and guard meet. but if i roll the guards will i still have trouble with this sized tire? or will i still need to go down to a 235/35? cheers
You don't have to go as small as 235/35 you can go 245/35's without rubbing on the edges (after rolling).
But you will still need to trim that bumper/body section.
also to note, ur speed would have increased compared to ur speedo, so dont speed too much lol
yes i have checked my speedo with gps, with my standard 17" rims when i was on 100kmh on speedo i was actually going 96kmh and now with these on when speedo says 100kmh i am going 101kmh, almost bang on.
I've always wondered about the reliablity of GPS's speed calculations. Am i right in trusting my speedo more?
i'm riding on 19" SSVs on 235/35 on Ultra Lows all round and i haven't had my guards rolled.
No issues !
I just think my centre muffler isn't as shiny as when it was put on haha
Oh wow, i never thought that would be the case. Next time i have a GPS in my ute i'm going to compare!
rolled guards with 245's 19in no problem
although when car fully loaded it does scrape on some decent bumps
