Results 1 to 3 of 3
Thread: vz troubles
    vz standard 3.6
    Jun 2011
    cessnock
    Default vz troubles
    Hi was after some help on my vz.
    The check powertrain warning has came up and its running really rough. I had it scanned and faults P0300 and P0303 came up. Any advice were to start?
    Cheers dom
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Cylinder 3 misfire if I remember correctly. Check the spark plug is sparking. If not it may be the coil. Google search answers 99% of questions.
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Which is the middle cylinder on thr RHS.
    Swap with another coil to see if the fault will reproduce on another cylinder. If it does replace it.
    BTW. Plenum needs to be removed or at least lifted to access.
  1. ABS Troubles.
    By fonzo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2010, 04:43 PM
  2. Troubles with my VK
    By Dazza_Bo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2010, 04:02 PM
  3. Vl Having troubles plz help me
    By Nackerz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-07-2009, 09:37 PM
  4. Amp Troubles
    By [NatHAn] in forum Car Audio
    Last Post: 16-02-2008, 10:44 AM
  5. VH 253 troubles
    By Portunio in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-05-2006, 08:09 PM
