Results 1 to 5 of 5
Thread: VZ V6 engine tick
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Default VZ V6 engine tick
    Hey guys. I started up my car tonight in the garage with no noise going on, and i heard a tick in the engine bay. It runs with engine revs, but not engine speed, more like valve tap.
    Has anyone had tappets loose enough to tap, are they ever adjusted in a service schedule? Or is it more likely a stuffed cam follower?
    The reason i'm so worked up about it is because i had the exact same symptoms(valve speed tap, vibration at around 1500rpm, slight decrease in performance) at work, but it was in a cng bus engine.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    perhaps get a video up, i had a 'tapping' that turned out to be a timing chain tensioner
    Life starts at 200km/h
    06 vz sv6
    May 2011
    south east sydney
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    hahaha the tapping in cng bus engines being valves, you're laughing haha, a tap in an engine at my work is more like valve recession or piston knock hahaha, as for your problem, i've heard a coupla timing chains ticking, valves can't be adjusted on alloytecs, they use hydraulic lash adjusters instead
    peace.
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Bored or just wanna talk about cars? Add me on facebook and we can talk
    http://www.facebook.com/#!/profile.php?id=1002697869
    VZ S 175 Ute
    Nov 2010
    Thanks for the replies, good to know about the hydraulic valves. Ive heard that the timing chain is a job and a half to get to. Worth changing chain as well? And can i get an aftermarket chain, apparently the oem chains are noisy. The tap is barely noticeable, and my exhaust noise would kill a video mic.
    I work for brisbane city council, and as for that bus, it was a MAN(MAN valves get tighter, not looser). The bus had a tick at full revs, and vibration at 1500. We did compression tests, missfire checks, valve adjustments. But when we turned the engine over with the tappet covers off for the 3rd time, cylinder 4 intake valve only traveled 3mm. to the naked eye it almost looked like it didn't move. The cam follower's hardened surface had failed and it wore the cam lobe flat. That's an expensive problem.
  1. Overheating - unknown coolant loss - tick tick tick - hard starting
    By Greg_Sian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2010, 07:46 PM
  2. 304 loud engine tick
    By Dinwoodie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-05-2010, 11:13 AM
  3. VE SS Engine Tick on Startup
    By Bevo in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-12-2009, 03:12 PM
  4. Tick, Tick, Boom!?
    By riewoldt12 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2006, 03:32 PM
  5. Engine Tick driving me NUTS!!!!!!
    By thespiceweasel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-09-2004, 11:55 PM
