Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By GEN3RATD
Thread: 20" tyre dilemma
    05 VZ Berlina
    Aug 2009
    Default 20" tyre dilemma
    Hey guys just need abit of help from a non-biased person (not from a tyre shop)
    I have had 2 sets of rubber on my 20" wheels...
    First set that came with the tyres were Zeetex hp 225/35/20 and second set are Kuhmo KU31 235/35/20
    both sets have lasted me around 20-25000 as i do 500km a week (MOSTLY highway/main roads) each set have lasted a year. Being a stock barge I dont race it nor have either set seen a single burnout.
    the zeetex are worth around 180ea and the kuhmo were 260ea
    both sets had around 10-15000km left on them but both sets have had air bubbles in one or more of the tyres and also both sets had tyres that started to split.
    my problem is I now need to get new tyres but dont know what way to go...the kuhmos drove great but at 70ea more a tyre im not sure if its worth getting again if it will last the same time. Then again i suppose $280 extra may be peice of mind for the kuhmo's. Might i also add i have always run 40psi though them and do get them rotated from time to time but the kuhmos were only aligned when fitted (august 2010) and i havent had one up until yesterday.
    My question is what do you guys recommend? my car is an 05 vz berlina so i do have the option of different load ratings (92/93/95) etc etc although the 235 do scrub the rear guards even though they have been rolled.
    Any help would be great.
    Nick
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    dont get diamond backs lol, in the end, it does pay off to get a good brand like bridgestone, as they last longer, and wear more evenly. the rubber compound in them is also good quality compared to cheaper brands
    Spoken by a true member of The Committee
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    I have Dunlop SP3000A. No complaints and pretty good in the wet.
    A lot of guys recommend Toyo Teo or Falken 452.
    Do not buy cheap tyres!
    VZ Calais
    Oct 2008
    I have Toyo Proxes 4's and they're fantastic. I had Nankang's before and I thought they were rubbish, especially in the wet and they wore really quickly.
    Like the others have said, don't skimp on tyres. Not only safety but nothing worse than buying crap tyres, having them wear quickly and having to buy more.
    undersuspicion is offline Now That's How We Roll!
    Vy SV8 Series 2
    Aug 2010
    +1 for toyo proxes, a great tyre i have found.
    don't take this wrong or anything but ARE YOU ####ED IN THE HEAD????
    Reaper
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    Quote Originally Posted by heyitsEnricoPallazzo View Post
    Falken 452's are insane, in both performance and cost
    If it isnt tuckin, it must be suckin
    VZ SV6 UTE
    May 2011
    i am having the same problem at the moment not knowing what tyres for my 20s, on my old set of 20s which were stolen luckly had insurence i swear they were alot fatter compared to the ones now which are 225/30/20 i think which look dreadful and skinny? just wondering would 245/30/20 fit all four or any other suggestions?
    cheers
    VZ A4 Saloon
    Nov 2010
    Can't speak for the rear in your case. But 245's on the front are mighty close to the strut spring seat.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    I would go 245/30R20 for sure, more rubber on the road, less likely to rash your wheels etc etc.
    As for tryres, for budget 'performance' tyres you can't go past Federal 595, people often compare them to the KU31 but I have used both and liked the Federal a lot better, better wet grip, quieter tyre. If you are wanting something cheaper, but not exactly Chinese crap i'd go for some Nexens. Nexen are generally pretty good, the N6000 range etc still handle very well in the wet, especially considering their price. Better than Fulcrum and roadstone and triangle and all the other cheap cheap stuff out there.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VZ SV6 UTE
    May 2011
    Default 20 tyres
    Lol!!! Fulcrum is that real brand lol.. Yeh that what I was leaning towards just keep getting mixed ideas, note that I haven't got rolled guards and it's. Not lowered and it's a sv6 ute. So 245/30/20 u think will be sweet?
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    I rate nexen N3000.. they are a mid range tyre, mid - hard compound, soften up when hot and in the hills, last a while, and handle great in the wet..
    Life starts at 200km/h
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Quote Originally Posted by DM 55 WA View Post
    This^^^^
    I wouldn't get anything else on my car.
    N/A
    Nov 2009
    I know you didn't want advice from a tyre store but this ^^^^^ is exactly why advice from a tyre store is needed. It's all very well to specify that one tyre is better than another, but it's another thing to look at your available options..many of the tyres recommended above are NOT available in the correct LEGAL size for your vehicle. If as your details suggest, you are driving a VZ - then there is only 1 tyre size which is legal on your car and that is a 245/30R20.
    225/35R20 is outside the legal 15mm restriction as is 235/35R20 (unless it's a ute or came with standard 215/60R16)- I know, I know, many people run a 225/35R20 - reason: they are cheaper than equivalent 245/30R20's and the range is bigger. Also they were available long before manufacturers started making 245/30R20's...
    Now looking at the 245/30R20 you need to bear in mind that you need a min 92 load rating...sooo... you need an XL (Extra Load) 93 tyre. This limits your tyre options significantly to ~ 4different brands (possibly more but not many and definately no premiums)....
    Achilles ATR Sport, Neuton NT5000, Altenzo Sport Comforter, Nankang NSII.
    All of the premium tyres available in the 245/30R20 size are only 90 load rated so won't be legal.
    I'm not trying to rubbish the recommendations made above, but simply trying to highlight that many of the recommendations are inappropriate for your vehicles tyre size requirement.
    www.thewheeldeal.com.au
    Ask me for a great deal on tyres & wheels shipped Australia wide.
  15. #15
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    Quote Originally Posted by thewheeldeal com au View Post
    this is correct, i found the same with my SS. i had to get the Altenzo's and they are terrible, id much rather Nankang's.
    correct me if im wrong but i believe maxxis also make a 245/30/R20 93W tyre
  16. #16
    Dec 2008
    ^^ Good advice as always, from personal experience I would not go near a Nankang NSII again, wore very badly, bad wet grip. Surprisingly the Achilles ATR Sport I found to be much better, though still a very affordable tyre.
  17. #17
    VZ SV6 UTE
    May 2011
    Wheeldeal^^
    cheers for the advice mate finally a straight answer from someone, was looking at old picture off old wheels and I think I can make out they were actually nankangs. Il have look around see how I go will keep up to date with what tyres I get
  1. [SA] 1 VY SS 17" Mag With Tyre
    By ENV5 in forum Parts And Other Items For Sale
    Last Post: 17-08-2009, 07:01 PM
  2. WTB: x1 19" Tyre, 40-50% Tread
    By dawg in forum Swap / Wanted to Buy / Trade
    Last Post: 21-08-2008, 07:06 PM
  3. FS: 1 x 18" RE040 tyre new. SA
    By SIG-054 in forum Parts And Other Items For Sale
    Last Post: 29-04-2008, 10:12 PM
  4. VY SS 17" Rim & Tyre
    By lukedog in forum Swap / Wanted to Buy / Trade
    Last Post: 29-06-2006, 10:40 AM
  5. WTB: VY SS 17" RIM with or without tyre
    By Henerz in forum Swap / Wanted to Buy / Trade
    Last Post: 08-05-2006, 11:08 PM
