Results 1 to 9 of 9
Thread: vz exhaust
    vz storm ute
    Mar 2011
    perth
    Default vz exhaust
    i have a vz v6 with pacemaker extractors and a manta exhaust 2 1/2, i bought the car like that it makes a bad hissing noise when i gas it and sounds terrible on start up, more so when its cold. what is going on!!
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Rattle at startup?
    I had a similar problem when giving it the beans. Turned out to be a RH brake line from the ABS module chafing on the inner guard.
    If you give your brake line array from the ABS a tap with an open hand you might produce a rattle.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Could be a leak in the exhaust somewhere.
    Do you still have the standard intake?
    Visit my Facebook page
    vz storm ute
    Mar 2011
    perth
    yea std intake im thinking a gasket but i dunno where to look!! would intake change much?
    vz storm ute
    Mar 2011
    perth
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    An aftermarket intake tends to hiss, that's all.
    The gasket I would be looking at is where the extractors finish. Just start the car up and get under it and listen basically. Where the noise is loudest will be where the leak is. Even easier to find if you had someone hold a rag over the tail pipe.
    vz storm ute
    Mar 2011
    perth
    is it easy to get ahold of another gasket? i mean do i need a special one or just standered sizing??
    vz storm ute
    Mar 2011
    perth
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You will need the correct gasket that fits. If it is just a gasket. The best way to do it is to unbolt the join and take the old gasket in to an exhaust shop and match it up. Or take the whole car in and get it checked over properly on a hoist.
    Depending on what is wrong with it, if the exhaust has a hole in it, I do Manta as well so I can supply a replacement part. If you wanted to come down to Bunbury, I could even fit it for you.
  1. [VIC] FS Monasro exhaust, vx ss exhaust, K&N filter, various Maf's LS1 turtle shell & more
    By SenatorMike in forum Parts And Other Items For Sale
    Last Post: 10-04-2011, 10:39 AM
  2. Steam coming out of exhaust, also notice liquid sitting in exhaust tip
    By v8s&2wheels in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-07-2010, 12:35 AM
  3. [VIC] Swap my sports exhaust for stock standard exhaust - vu ss - cat back
    By supachippy in forum Swap / Wanted to Buy / Trade
    Last Post: 21-06-2010, 12:05 PM
  4. [VIC] HSV R8 exhaust system -suits all Twin Exhaust VE Sedans
    By vol800 in forum Parts And Other Items For Sale
    Last Post: 13-01-2010, 05:37 PM
