Results 1 to 2 of 2
Thread: Ideas for a squeaky Calais?
    VZ Calais
    Oct 2008
    Default Ideas for a squeaky Calais?
    I have a V6 VZ Calais, which has developed a random squeak that my mechanic and I cannot find. It is entirely stock.
    When I bought the car, the water pump was on the way out and the timing cover gasket had a slight leak. Neither required urgent attention. A squeak began to develop during this time.
    I had the water pump replaced about 7 months ago, only to have the new one fail a month ago.
    I took this opportunity to have to timing cover gasket fixed and the water pump replaced. The squeak got worse so the belt was replaced as it had been soaked by leaking coolant. The squeak didn't go away but got quieter.
    The belt tensioner had some side to side play in it so that was replaced with a new one but the squeaking continued.
    My mechanic found the alternator was noisy and after pulling it apart found the grease had hardened to almost a wax state. We were certain this was the problem so replaced it with a new alternator.
    However it is squeaking still. It is particularly bad from a cold start and after 10-15 minutes of running the squeak disappears. There is no noise at idle but starts to make noise from 1200 rpm upwards, particularly noisy at 2000-2500. It still makes the noise when revved in neutral so it is not gearbox related.
    If you have any idea what it could be or have had a similar problem please let me know.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    how are the idler pulleys?
    Spoken by a true member of The Committee
  1. VX calais 5.7 , clicking noise from left rear wheel area, any ideas ?
    By comfortss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2011, 09:55 PM
  2. Replies: 2
    Last Post: 02-07-2009, 08:00 PM
  3. I need some mod ideas for my VN Calais
    By markER717 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-06-2009, 10:19 PM
  4. VS CALAIS need some ideas on what to do to it!
    By VSCALAIS6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2009, 05:09 PM
  5. VP Calais Fuel Leak... Ideas??
    By VT_R8ted in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-04-2006, 06:57 PM
