Results 1 to 20 of 20
Thread: VZ problem
    2005 VZ Wagon
    Sep 2008
    North Shore, NZ
    Default VZ problem
    hey fellas,
    I know jack about engines etc so was hoping you guys may be able to help me out with some info so I don't sound like a right muppet when I go to the mechanic and then they rip me off.
    Anyways my 2005 VZ wagon was starting to shudder in the rear when I went to accelerate whilst doing about 90kms. I was in 4th gear and it only seemed to shudder when in low revs, when the revs came up it was fine. I limped home but when I got to a red light on the way it was really spluttering and about to stall whilst stationary at the lights. When driving at 40-50 it seemed to shudder a lot more. At home while opening the garage I could smell a rich, burning, smokey type smell coming from rear/exhaust area (sorry bout the explanations I not too sure how to describe it).
    If anyone has encountered the same problem or may know what this could be please let me know, I'm stressing a bit that it's a major.
    Thanks heaps guys
    Max2
    SGM304
    Jul 2010
    Kadina
    2005 VZ Wagon
    Sep 2008
    North Shore, NZ
    Quote Originally Posted by slammedvz View Post
    is it missfiring? coil pack more than likely
    misfiring....um when I hit the gas it seemed to struggle and hence the shudders, is that misfiring?
    What's a coil pack mate and what's its function? sorry dum dum here lol
    2005 VZ Wagon
    Sep 2008
    North Shore, NZ
    ok i googled coil pack, know what it is now
    sounds like that could be a possibilty, thanks slammedvz
    impulsive's Avatar
    impulsive is online now Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    with no mech experience, chances are if you cant diagnose it you prolly cant fix it.. i would be visiting a mechanic to be sure..
    Life starts at 200km/h
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    check your tailshaft couplings however, sounds like an issue i had recently..
    2005 VZ Wagon
    Sep 2008
    North Shore, NZ
    Quote Originally Posted by impulsive View Post
    definitely won't be fixing myself, just hoping to get a bit of info so I sound like I half know what I'm talking about when I go to the mechanic.
    thanks impulsive
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    do you know when your spark plugs have been changed? how many km on the car? spark plugs are meant to be changed at the 120,000km service intervals.
    Spoken by a true member of The Committee
    2005 VZ Wagon
    Sep 2008
    North Shore, NZ
    it's done 118,500 kms so due for a service soon, It hasn't had new spark plugs while I've had it since 74,000kms.
    Do you think it could just be stuffed plugs?
    1970 AMC javelin, S2 stagea
    Jun 2008
    If it misses at idle you can try unplugging each coil individually to trace which cylinder is misfiring, you should notice a difference in engine revs and tone when each coil is unplugged, if there isnt a difference then you will know which cylinder is misfiring.
    Then check the sparkplug or even swap the coil to a different cylinder and do the same test, then if the misfire in that cylinder you've found the coil pack is gone.
    Hope this helps.
    vz berlina alloytec
    Jul 2011
    australia
    2006 VZ commodore Acclaim
    Jan 2007
    Ipswich QLD :(
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by jav360 View Post
    Hope this helps.
    Bad idea to unplug COP ignition when operating. Or any electrical or electronic device for that matter.
    WL CAPRICE
    Mar 2011
    Quote Originally Posted by heyitsEnricoPallazzo View Post
    Bad idea to unplug COP ignition when working. Or any electrical or electronic for that matter.
    Opps Iv done that on my previous car to diagnose which coil was buggerd.
    Couldnt think of another way of working out which coil is causing the problem.
    If you have loss of power it's most Likely a coil, if it just does a shudder noise at certain revs of certain speed it could be ur torque converter.
    These are your coil packs:
    3 on each side if the engine underneath the intake manifold plenum.
    Not too hard to do urself if ur a lil mechanically minded.
    Good luck
    Dave.
  15. #15
    2005 VZ Wagon
    Sep 2008
    North Shore, NZ
  16. #16
    2005 VZ Wagon
    Sep 2008
    North Shore, NZ
    thanks Dave and everyone, gonna take it in next week, will let yous know what it is
  17. #17
    2005 VZ Wagon
    Sep 2008
    North Shore, NZ
    It was a coil pack in the end, they had to take the manifold off and farked the gasket so I got charged for that too!
    all sorted now tho so thanks again fellas for the advice
  18. #18
    WL CAPRICE
    Mar 2011
    Quote Originally Posted by CAPRILICIOUS WL View Post
    Good luck
    Dave.
    It's good to hear uv got it all sorted
    Usually the gasket has to be changed whenever u lift the intake manifold. They should have replaced it with the metal one which is reusable and shuld have cost u no more than $50.
    How much did it cost for the coil if u don mind me asking?
    Dave
  19. #19
    2005 VZ Wagon
    Sep 2008
    North Shore, NZ
    Dave
    cost me NZ$881 all up for the coil pack change, new gasket, service (oil and filter change and checks) and new spark plugs.
    I think the coil (part only) was roughly NZ$150 and I got charged NZ$118 for the gasket!
  20. #20
    WL CAPRICE
    Mar 2011
    Ouch, lol
    That's a decent price for the coils, some mech tried ripping me off by charging me $220 for a single coil, but I knew where he got his parts from and I put him on the spot and paid only $116 for one.
    It was after that that I taught my self how to do everything on my car my self.
    Well it's good that uv done coils plugs and service all together now u know u have a healthy running engine.
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  3. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  4. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
