Results 1 to 5 of 5
Thread: weeping/dripping coolant
    vz
    Jul 2011
    gisborne
    Default weeping/dripping coolant
    Hey Guys
    I've put a deposit on a 2005 vz exec 145000kms.
    It ticks all the boxes. I called it the unicorn because I thought it I would never find it.
    The local g.m.h dealer sold it new;the
    same dealer serviced it regularly for the fleet owner
    they traded in at same dealer.
    Same dealer sold it 2nd hand to the 2nd owner
    He serviced it at the same dealer.
    Seller took it to the same g.m.h dealer for a roady today.
    They picked the screen as chipped and now the scary one,
    coolant "dripping or weeping " from behind the timing case.
    The seller had brought the unicorn from the same dealer 9 mths earlier and got an aftermarket used car warranty at time of purchase. 2 months ago he got the water pump replaced under the warranty and then 3 weeks ago he found a few drips still going. Took it back to the dealler who replaced the radiator hoses.
    Must of been something going on around there.
    The holden dealership gave him a quote of $1500 to rectify the problem they found today.
    Sounds like the dealer knew it was there and tried to do a patch up.
    doesnt look like the warranty will cover this job
    he freaked and ranaway with the unicorn.
    He Called me later today and said he took it to a radiator place who did a pressure test and found zilch. The seller believes the dealer was just trying to drum up a bit of work ."hmmm"?
    I've looked at lots of vz's previously, and more than one seller said they had this issue addressed between 120/150kms.They said its a butterfly shaped "o" ring in there that perishes.
    As of tonight no R.W.C has provided.
    I'd like to put it out there for ya thoughts.
    Is this rare? common? unusual?
    Is $1500 over the top for this work?
    vz v8 wanna be
    Sep 2010
    caloundra
    any thoughts guys?
    id like to know too, because i have what seems to be a similar problem
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    so where is the used car 3 year 175000 warranty that this dealer provides?
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    If it's leaking from the seal you mention the coolant should also have mixed with the sump oil. In that case I would run away.
    Additionally, I would have thought that seal would not show any external signs of coolant if it has failed.
    Never heard of the seal in question failing or any issues relating to it.
    impulsive's Avatar
    impulsive is online now Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    he said warranty doesnt cover it..
    Life starts at 200km/h
  1. VS v6 coolant dripping from trans...
    By Kingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2010, 03:21 AM
  2. coolant dripping from sump?
    By pillzor in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2010, 02:30 PM
  3. Weeping Oil
    By holdenvtman1123 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-03-2010, 02:49 PM
  4. Air Con Water Dripping?
    By mbvp73 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2010, 04:47 PM
  5. dripping
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2005, 05:37 PM
