Results 1 to 2 of 2
Thread: RIM upgrade
    Vz SV6 my06
    Jul 2011
    marburg
    Default RIM upgrade
    HEy guys i wanted to chuck a pair of weld prolites on the back of my sv6 just wondering can i do this all will i end up sheering off a stud like veryone is telling me
    Oh you drive a VZ ??? Do you want me to take my clothes off now or in the car
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    The only reason you could shear off studs would be if the wheel doesn't rest on the hub, eg if the centre bore of the wheel is larger than the hub bore.
    Then the weight of the car would be on the studs instead of on the hub.
    You can buy hubcentric rings to fit inside the wheel hub bore to mate up to the axle hub, you just need the hub size and the wheel bore size.
    HUBCENTRIC RINGS HUBCENTRIC CHEVY GMC BUICK CADILLA | eBay
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  1. Brake upgrade kit - missing bolts!?!? (RDA VE upgrade for VS SS)
    By gsxr6000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2011, 10:35 AM
  2. VR to VS BCM Upgrade
    By Bilbs in forum Projects
    Last Post: 16-11-2010, 08:12 PM
  3. What to upgrade
    By madsav in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2010, 09:09 PM
  4. map upgrade
    By CHISEL in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-06-2009, 04:38 PM
  5. Cat Upgrade
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2006, 08:42 PM
